Old 02-08-2017, 09:00 AM   #1
MarkZ
MarkZ's Avatar
Drives: 2016 Camaro RS 2LT
K&N Performance Intake Kit now Available
Not sure if this is old news or not, but I just got notified of the availability this morning.
http://www.knfilters.com/search/prod...x?prod=63-3094
Seems to not require a tune.
Mark
MarkZ is offline   Reply With Quote
Old 02-08-2017, 10:05 AM   #2
Gen6Rs
Gen6Rs's Avatar
Drives: 16 black RS
thats awsome. much cheaper and better HP increase but weird dyno graph. Seems very low but they are only using 2nd gear. Most placed use 5th but run into speed limiter. 4th gear seems most optimal but still very low numbers all in all considering I got 269 stock.
Gen6Rs is offline   Reply With Quote
Old 02-08-2017, 10:47 AM   #3
AlphaCamaro7
AlphaCamaro7's Avatar
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85
Great post. I was waiting for this. First of all if the 21hp increase is legit than that's crazy. Second only 197 ft lb??? That's so low. I wonder if anyone knows what's wrong with that.
Well............ At least you tried. lol
AlphaCamaro7 is offline   Reply With Quote
Old 02-08-2017, 10:50 AM   #4
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
It's really hard to dyno the V6 in the correct gear without having the car tuned to remove the speed limiter. A limit that's dangerous to exceed on a dyno on stock tires since they would not be rated to go much faster than the limiter and could explode on the dyno. Probably just not common to come across those necessary changes on a V6 around them. So they tested in a lower gear which impacts the results.
Old 02-08-2017, 11:18 AM   #5
AlphaCamaro7
So what about the 21hp increase? Is that legit?
Old 02-08-2017, 12:22 PM   #6
cellsafemode
i didn't get it dynod on my car. You're gonna find just as many people who trust a company's numbers as you will who give you any number of reasons why you shouldn't.
Since it seems essentially the same as the GM intake, i'd assume you'd get the same perf as that more or less. Though minus that re-cal tune (which nobody really knows the details of).
Old 02-08-2017, 12:30 PM   #7
AlphaCamaro7
Glad this doesn't require a tune and it's $200 dollars cheaper.
Old 02-08-2017, 01:31 PM   #8
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
But technically voids your warranty
Dustya is offline   Reply With Quote
Old 02-08-2017, 01:42 PM   #9
AlphaCamaro7
Takes 20mins to remove but I've never heard of dealers voiding warranty because of an intake. Especially from an experienced company like K&N. I had their filter on my mazdaspeed3 for years and took it in to the dealer many times and for repairs and they never even questioned me once.
Old 02-08-2017, 02:15 PM   #10
Goobaba
Drives: 2016 V6 RS Manual
Thats at 5900 RPM, that's why its low
Goobaba is offline   Reply With Quote
Old 02-08-2017, 02:17 PM   #11
Goobaba
21 HP max gain at 5900 RPM, looks like peak gain is no more than 10HP, maybe even less.
Old 02-08-2017, 02:48 PM   #12
TatsuSensei
TatsuSensei's Avatar
Drives: 2016 RS Hyper Blue
Well, it sure does look nice too. Ordered. Will be here Friday and installed this weekend.
TatsuSensei is offline   Reply With Quote
Old 02-08-2017, 03:47 PM   #13
AlphaCamaro7
Great man, good for you, can we expect maybe a review or your thoughts? Maybe a video?
Old 02-08-2017, 06:52 PM   #14
bishopski
bishopski's Avatar
Drives: 2016 Camaro LT | 3.6L V6 | A/T
Price seems fair but their numbers.....hummmmm
2016 Camaro LT | 3.6L V6 | A/T | Summit White w/Black RS Stripes
bishopski is offline   Reply With Quote
