![]() Drives: Black 2017 Camaro SS 1LE Join Date: Jan 2017
Sold
Sold
![]() Drives: 2017 1ss Join Date: Jan 2017
im just asking ....but do you know if it just plugs into existing wiring for an ss . new wire need to ran , or requires a flashing of the body control module to work ?
I have no idea. I'm assuming it's probably plug and play. But that's an assumption. The only difference between mine and this is the suede and heat. Everything else is the same. So I'm guessing the heated wheel just needs power to operate.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE Join Date: Mar 2016
As far as we know right now there is no way to get the heated wheel to work on a 1SS or 1LT :(
IG: @NC_M1SS1LE
Bummer, I haven't even tried. I was too unsure to tear into the car. Kind of an impulse buy
![]() Drives: '16 Red Hot 2SS M6 NPP Join Date: Apr 2016
It's plug and play. Someone on here bought a new ZL1 suede wheel and it swapped to a 2SS with no issue.
From what I understand, the 1SS will fit, but there is no harness to plug the heated part in so it does not work.
![]() '16 2SS, M6, Borla Atak |
#7 |
Nice to know! Thanks
#8 |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
Can confirm AdmAnt is correct. This wheel should at least fit on to any trim level of 6th gen Camaro, but heated wheel won't work since it's a separate wiring harness not included unless your car came with a heated wheel as an option from the factory.
I'm pretty sure the controller for the heating element is located in the wheel itself, all you'd need to do is provide power if that's the case. I'm currently looking into the best way to do this since I want to add a heated wheel to mine. I'll start a thread in one of the technical forums if I find anything useful.
2017 SS 1LE.
#9 |
This is still for sale... along with the matching suede manual shift knob
#10 |
![]() Drives: 2016 Camaro 1LT Join Date: Apr 2016
#11 |
![]() Drives: 2017 2SS Join Date: Jun 2014
Bone - I don't suppose you'd be willing to take that shift knob to a Home Depot/Lowes and see what thread pitch and size the hole it, huh? A lot of people are wondering, so we can get aftermarket knobs.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '22 Silverado 2500HD Duramax LTZ Join Date: Dec 2015
I believe the OEM knobs snap on.... not threaded......
#13 |
SABIO
R is on the wrong side....
My bad. V6 Knob.
#14 |
![]() Drives: 2017 Camaro 1LT HBM Join Date: Sep 2016
