Old 02-03-2017, 08:58 PM   #1
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
FI and Meth
I never liked nitrous, and I'm still reluctant to add a second source of fuel, but I can't imagine a more suitable setup than this FI DI engine out of fuel, and with a huge cost involved in taking the next step to upgrade that fueling. And especially when that next step has been found still lacking in providing enough fuel to fully support E85. Meth is under half that fueling upgrade cost.
Additional benefits are the charge air temp reduction, addition octane>timing available, and valve cleaning effect.
It sounds like a no-brainer to me. Why don't we see more cars running FI + meth on this forum?
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 02-03-2017, 10:47 PM   #2
BravoMyles
BravoMyles's Avatar
Drives: Blue/Black 2017 1SS
I'm curious as well. I likely will eventually on my car. My cam doesn't have an increased fuel lobe and it seems like a logical choice to add meth as opposed to a cam swap or pump/injectors. I mean, eventually I'll probably swap to a better cam, but I could stick with mine now and just run meth for added fuel.
2017 1SS - Hyper Blue Metallic
Heads, Cam, e85, 3600 Stall, Full bolt-ons, MBRP exhaust
2010 2SS - Summit White - SOLD
CAI intake, Borla Atak axle-back (Summit xpipe resonator delete), custom ported TB, Texas Speed 1 7/8" LT Headers w/ Catless connections
Instagram: bravomyles
BravoMyles is offline   Reply With Quote
Old 02-03-2017, 11:04 PM   #3
1LE801
"Lohla"
1LE801's Avatar
Drives: 2016 1SS A8 :"Lohla"
I'm a believer! Too many positives not to run it IMO....
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
1LE801 is offline   Reply With Quote
Old 02-04-2017, 01:34 AM   #4
SSFanboy
SSFanboy's Avatar
Drives: 2016 Camaro A8 2SS w/Maggie
I'll start with the reason why I've decided to upgrade to the LT4 fuel components over meth:
- High Maintenance: I don't want to mix methanol with distilled water, clean nozzles, or if using a high concentraton of methanol, regularly fill a container with a flammable liquid from anything other than a gas pump.
- Long-term cost: A 5-gallon pail of pure methanol is $80-$90. I could purchase a 55-gallon drum of methanol and get it cheaper, but who wants to store that in their garage? I plan on keeping my vehicle for a while so I figure upgrading to the LT4 high and low-side pumps + injectors is cheaper in the long run. Now if I throw in a CAM + all other components that typically go with that, we're talking major $$$...so I'm re-thinking this argument.
- Reilability: I know many kits come with fail-safes, flow guages, and reliable pumps, but that's one more set of components to worry about. With any concentration higher than 50/50, I'd have to worry about corrosion leading to leaks in hosing or storage containers. I suppose I could take precautions by using stainless steel lines and some type of race tank for in-vehicle meth storage.
I'm not gonna lie, there are some definite PROS that have tempted me:
- HP Monster: The horsepower gains can be phenomenal with the right tune and when combined with FI, higher compression, and smaller SC pulleys.
- Cleaner valves: No need for my catch can
- Lower IAT: Not really a concern with my Maggie and its awesome intercooler, but if I keep modding and decide to track the car, water/meth injection may be very helpful after multiple runs or after heat soak.
- Less chance of knock if you want to significantly increase boost...or so I've heard.
- Massive TQ curves: Already got that with my Maggie but still impressive if you've got slicks to put it down and ZL1 axles to keep it down.
SSFanboy is offline   Reply With Quote
Old 02-04-2017, 05:45 AM   #5
ADM PERFORMANCE
Drives: Anything I want
Took the words right out of my mouth. I read on Facebook recently a newly installed METH System stuck on for no apparent reason,until the problem was diagnosed. The fix was to use "FLEXSEAL" to seal the box full of electronics. Really!
The problem is that he manufacturers of these kits are using subpar components with no safety behind them or Logic.
Methanol as well as e85 is highly corrosive(People that use it know) and can give Aluminum and Steel parts a short lifespan as it effects it metallurgy with time causing tolerances to no longer be within spec. This in turn leads to failed parts. The more you use the faster they fail. JUST LIKE DRUGS DO TO HUMANS
My .02
A quote from flexseal website under q&a -
Q: Can I use Flex SealŪ to fix radiators, tires or other areas with extreme heat and pressure?
A: NO, Flex SealŪ will withstand your normal water pressure but it's not made to withstand extreme heat or pressure.
ADM PERFORMANCE is offline   Reply With Quote
Old 02-04-2017, 07:44 AM   #6
laynlo15
Drives: 2022 Lt1 A10
I'm deff on the fence about this also. I'm thinking maybe it would just be best to have 2 tunes, one with a pulley change and race gas for the track and one for the street for 93 instead of messing running the meth. The pulley and a reflash takes less then an hour if you have hp tuners as I do. I'll be drag racing a couple times a month once our tracks open and I don't need 600 rwhp on the street, but want it at the track.
Old 02-04-2017, 08:08 AM   #7
1LE801
"Lohla"
1LE801's Avatar
Just don't buy a cheap kit. It's no different than anything else. You get what you pay for.
E85 is great but it's not cheap to switch to and the pump E85 has been proven to be nowhere near E85. Availability is more scarce and E85 doesn't clean or cool like Meth. It also is far less efficient meaning more fuel needed meaning more money spent.
To each their own but a GOOD Meth kit is a hard to beat.
Old 02-04-2017, 08:50 AM   #8
SGDM
SGDM's Avatar
Drives: 2016 2SS
You open a whole new can of worms with Meth, not the cooked kind. What do you want from your car? Is it a DD, weekend track/strip car that you haul on a trailer. Crap fellas...these FI cars are pushing 600 now on stock fuel system and pump gas! You have to use extreme caution using meth, storage, mixing, tanks, lines, etc. I have seen cars running meth get a leak or pop a line. You will be lucky to get out. Just sayin.
Who Dares...Wins
SGDM is offline   Reply With Quote
Old 02-04-2017, 08:54 AM   #9
parish8
Drives: 17 SS a8
You do use more e85 than gas but here it is much cheaper than premium. The actual cost per mile drops with e85. The e85 at my local station has tested between e73 and e88.
Meth is also cheap here. Something like $2-3/gallon.
I think meth is great if your looking for that next 100-200hp or so over what your current octane or fuel supply will give you. I know I will want more than that eventually so I am working toward port injected e85.
Old 02-04-2017, 09:09 AM   #10
ADM PERFORMANCE
This is exactly why we sell HPTUNERS and EFI LIVE Autocal
Old 02-04-2017, 10:06 AM   #11
SGDM
SGDM's Avatar
Drives: 2016 2SS
That is my plan.
Who Dares...Wins
Old 02-04-2017, 10:11 AM   #12
wnta1ss
Drives: 2017 Camaro 1SS
For those who are going the meth injection route, do not allow the tank to run out. I have seen an engine blow because of that mistake (not my own).
Old 02-04-2017, 10:30 AM   #13
LibertyHill
I am not sure I would, but everyone probably feels that way initially after a big HP upgrade.
Thought about this too thanks to Goertz. I wonder if the LT4 adapter plates are thick enough for injectors, or if additional plates between the PD blower and heads could be used? It would be nice if the injectors could be hidden under the blower too but I'm not sure how much room there is.
Whats the best option to address fail-safe? It seems a solenoid to dump boost would be best since we can't pull timing without an aftermarket ECU right?
I searched and can't find much on alcohol damaging metal. I actually found more suggesting it could actually improve the life of a blower but most info is slanted pro-meth to support sales of course.
Old 02-04-2017, 10:33 AM   #14
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
So many things wrong with this post.
The cost to switch to e85 is simply the cost of whatever a tune would cost you, which you would be paying anyway if you went with a meth setup. You can literally drain the tank, fill up e85, and tune the car. No other costs involved.
Any additional costs involved with e85 is if someone elects to use a Flex Fuel system, in which case you can budget another $400. This is purely optional and NOT required to run e85.
The costs at the pump are a wash. The car uses 30% more fuel but also costs on average a $1/gal less at the pump. 91 here is $3.10 and e85 is $2.00.
Also my local pumps both have over 80% ethanol content.
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
