BYND GARAGE
Drives: 17' 1LT Turbo Join Date: Feb 2016
Warm Enough??
At What Temperature Do You Guys Considered Warm Enough To start Driving?? Personally I Don't Start Driving Till It's Between 110-120 but I want To Here Your Guys opinion..
Retired from Car mfrs....
New cars don't really need to warm up. Start the car ,wait for the gauges to settle down and go drive sensibly. Unless you're at -0° or something like that. Then I'd wait about 20-30 seconds. No need for more.
Drives: 2016 Camaro SS Join Date: Oct 2016
You want get the engine up to operating temp as soon as possible. I would however advise against going WOT until the engine oil is up to temp (175F+). This can take a while in the colder months.
![]() Drives: 2017 ZL1 HBM, M6 Join Date: Oct 2016
I prefer to wait till is about 60 degrees outside, sunny and dry roads. I don't want to get my car dirty.....
BYND GARAGE
That's what I've always done with my other cars but for some reason I feel comfortable just waiting till the temperature gauge says around 150
![]() Drives: 2012 Camaro 2SS Join Date: Jul 2014
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
winter driven and parked outside if it isn't snowing.. start her up, let the idle drop and drive away with a little care for a couple blocks.. done
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms. |
#8 |
![]() Drives: 16' Camaro 2/SS BlackMosaic A/8 NPP Join Date: Jan 2016
I wait for the initial growl to groan...back out of the garage after waking the neighbors from their slumber...as I make my way to where I roam... Post that!
#9 |
I need Teepee!
Drives: 2019 Camaro SS 1LE Join Date: Oct 2016
Fire it up and drive away.
#10 |
![]() ![]() Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
You only need about 15-30 seconds to get the oil circulated and then you need to get the car moving. As said before, no WOT, but every moment spent idling at below operating temp is wear and tear.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
