![]() ![]() ![]() ![]() Drives: 2016 Summit White 2SS Join Date: Sep 2011
Rear diffusers for a NON Npp?
is there anything out there for a non npp? Looking to buy the whole kit but every package that I found the rear will not work..
A Heartbeat Away.........
Drives: Not As Fast As I Would Like To Join Date: Mar 2016
Not quite sure what you are trying to do. If you want to change from non-npp dual exhaust to quad tip, this thread explains what I did.
http://www.camaro6.com/forums/showthread.php?t=450889
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. |
![]() ![]() Drives: 2016 1ss Camaro Join Date: May 2016
our diffusers will fit both npp and non npp vehicles!
Andrew Bettridge
Account Manager Extreme Dimensions 1-714-278-8000 EXT 17 andrew.bettridge@extremedimensions.com |
![]() Drives: 2016 Nightfall grey 2.0 1LT Join Date: Aug 2016
Do you have a single tip exhaust (2 overall) or a dual tip exhaust (4 overall) ?
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible Join Date: Oct 2016
You can order the rear diffuser right from the dealer and if they are a great dealer they will install it for you.... They did for me and it comes painted from factory...
#7 |
#8 |
I believe Non NPP would imply no quad tips
I have been looking for a diffuser solution on mine (non NPP) for awhile. Not a fan of the gray plastic. A few options from what I have found: 1. Get a quad tip rear splitter that looks better, have a shop cut of your tip and weld on quad tip to accommodate the new splitter 2. same as #1, except just get an aftermarket exhaust with quad to accommodate new splitter 3. Paint or plastidip your stock rear splitter for better look. I like #2
#9 | |
![]() ![]() Drives: 2016 M6 2.0T Join Date: Nov 2016
http://andersoncomposites.com/pages/contact-us |
#10 |
I am buying the stock rear diffuser that would accommodate the wuad exhaust and get a quad exhaust without valves!!
#11 | |
My goal is to achieve a glossblack look like this:
#12 | |
A few other members on here have done this with good results |
#13 | |
I know some members have bought a stock quad tip rear diffuser and installed it. I think it had a smooth plastic (instead of our textured) and had it painted with no problem |
#14 |
Yes. This is the option we were taking about earlier. When I see how much it is going to cost just for a gloss black diffuser considering: the diffuser with quad tip, the exhaust tips change and install (if not changing to a axle-back), the painting of the diffuser ... versus painting the actual diffuser, I wonder if it is worth it.
