01-30-2017, 06:18 PM | #1 |
Obsessive camaro disorder
2nd gear GRIND
its getting bad,,only 67k miles,,,anyone else have this issue?
**2010 2ss/rs**
01-30-2017, 06:40 PM | #2 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 Join Date: Jul 2012
The TR6060 is notorious. Some have had luck swapping trannny fluid to Redline - I didn't. Some have it happen when cold but goes away when it warms up (mine's like that).
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
01-30-2017, 06:54 PM | #3 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I have never had the notorious 2nd gear grind. This is even before I added the separate clutch reservoir and Amsoil tranny fluid. It was notchy, stiff, or rough before adding those, better now. I found that shifting, especially before the fluid is warm, before 3k rpms that the tranny would be more difficult shifting into second.
Oh and If the gear has been "grinded" before it may have damaged the gear or synchros.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
01-30-2017, 07:35 PM | #4 |
its more when its cold ,,but at the track its bad,,and im sure its warmed up by then
already pricing new clutch and performance slave,,was well as the replacing any inside trans parts,,bet thats gonna hurt the wallet....hope these trans are not to hard to r&r
**2010 2ss/rs**
