Old 01-30-2017, 08:36 AM   #1
parbreak
Drives: 2017 50th Camaro SS
Iridium Plugs and Rough Idle
Posting this here cause some of the tuners may know:
Anyone hear of iridium plugs causing a rough idle to the point it sounds like it's missing. There are no codes being thrown and YES I did check the gaps and all the plug wires are tight.
Even after 3-4 minutes of warm up, the car seems to stumble all over itself when pulling out of my street.
parbreak is offline   Reply With Quote
Old 01-31-2017, 12:13 PM   #2
1fastlsx
Drives: Twin Turbo
yes i have seen rough idle and funny miss with no codes, if you put antisieze on plug threads it may be causing a ground issue or lack their of, if you did pull plugs wipe off thrreads and around heads where they seat and see if that takes care of.
1fastlsx is offline   Reply With Quote
Old 01-31-2017, 02:22 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
If anything they fix rough Idle issues.
Sounds like you may have a cracked plug.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-31-2017, 03:13 PM   #4
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
the stock plugs are iridium. and you dont need to post multiple threads of the same thing in various sub forums.
So i'd go with installation error.
Old 01-31-2017, 08:58 PM   #5
parbreak
And I don't need a lecture on how to post. I was a mod for many years on LS1Tech, but thanks for your response.
Old 02-01-2017, 08:52 AM   #6
JANNETTYRACING
Any other modifications that may be affecting your calibration?
Ted.
Old 02-01-2017, 12:06 PM   #7
parbreak
Hey Ted,
Thanks for asking. Only thing else that was done was a K&N Air Filter. My son bought me the air filter and plugs as a Christmas present and installed them. He put in the air filter first and everything was good and then about 3 weeks later he installed the plugs. He later told me after all these issues that he dropped #8 plug. I have new AC Delco coming in and going to change them all back. Hopefully the cracked plug is all that is wrong.
I would also like to give you a call sometime about SC and tuning on my '17
Thanks
Old 02-01-2017, 12:36 PM   #8
JANNETTYRACING
Hey Ted,
Thanks
You are welcome.
I will assume a Drop in K&N?, this would have no effect on the calibration on the other hand if a K&N cold air kit your car would be lean.
Feel free to call me 203-753-7223
Ted.
Old 03-03-2017, 05:48 PM   #9
FdeleonZ28
Drives: 2016 camaro ss convertible
any update on this? having the same issue.. green drop in filter, plugs are fine .gapped at .35
FdeleonZ28 is offline   Reply With Quote
Old 03-04-2017, 10:31 AM   #10
JANNETTYRACING
0.035 is too tight open them to 0.042
Old 03-07-2017, 12:20 PM   #11
FdeleonZ28
forgot to mention I have 1 step colder plugs for spray
