01-29-2017, 07:44 AM | #1 |
Drives: 2016 Camaro V6 RS, 2005 Mustang GT Join Date: Sep 2016
Lag when acceration from stop?
I have a 8 speed auto, there is sometimes a lag when accelerate from a stop. There isn't when I go to WOT tho. Anywhere before that there is a small lag sometimes from when I push the gas in to when I start to move. Could it be the transmission wondering what gear to goto? Or something else? When I goto WOT there is sometimes a lull then a lunge forward from a stop. It is not smooth at times, other times it is completely smooth. What do you guys think? Oh side note, it's just broke 5k miles so I need to get it services as well.
2016 Camaro RS V6, Custom Leather interior, Flowmaster American Thunder exhaust, x pipe
01-29-2017, 07:57 AM | #2 |
Drives: 2016 SS Hyper Blue Join Date: Jan 2016
M6's have it too. My personal biggest complaint on the car. Just how GM decided to tune it factory is my guess. Too mushy in my opinion
01-29-2017, 08:28 AM | #3 |
Drives: Fast Join Date: Dec 2012
It's normal and I've had a lot of success tuning it out in the Overkill tune development. Also removed the dead pedal when traveling 40+ mph where you put your foot back on the gas pedal and nothing happens for the first travel, then suddenly there's life. Working to get the throttle pedal feeling normal and natural!
01-29-2017, 08:41 AM | #4 |
Drives: 2016 SS Convertible Hyper Blue Join Date: Apr 2016
That's why a lot of us are getting the Vitesse controller. Helps reduce that input lag.
Blacked bow ties, full bigwormgraphix blackout
Gm splash guards Mishimoto catch can Black hash marks Curb alert Vitesse controller Jl audio HD 900/5 amp c5 650 components c2 650x coaxials rear fill 2 x 8" W3v3 subwoofers custom ported box Fix 82 module BF TPNS BF Wet Diamond BF Crystal Seal Hydr02 303 Aerospace top protectant |
01-29-2017, 08:54 AM | #5 |
Drives: SS Join Date: Jan 2017
And here I thought it was just GM's way of limiting wheel spin in 1st gear on the M6. lol.
01-29-2017, 12:17 PM | #6 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
throttle controllers reduce lag in the same way that you can reduce your own lag by having a quicker lead foot. That's basically all they do. You can adjust your driving or you can use a controller like that to try and match the pedal sensor to your own behavior. No difference.
To remove the initial throttle lag for part throttle acceleration you need to tune it out. Not sure if the GM tune with their intake does anything to it, but you go trifecta or perhaps some other tunes... having it dyno tuned would probably fix you up. I'm not sure with the Trifecta tune (which i have) if it's the TCM tune they provide that corrects it or the ECM one. But it was gone after. And you have a 2016 so either way, you're good. Unlike the 2017 people who have to jump through hoops with the TCM. |
01-29-2017, 01:13 PM | #7 |
Drives: 2016 Camaro LT | 3.6L V6 | A/T Join Date: Dec 2016
2016 Camaro LT | 3.6L V6 | A/T | Summit White w/Black RS Stripes
01-29-2017, 02:48 PM | #8 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Also...ported tb... that helps with throttle response. First thing I added this time around. resons for it, is usually the porting, increase the venture effect. the air flow velocity increases slightly, and takes care of the lag. if diablosport comes out with their tuners, they have whats called "throttle boost" basically its the same thing as the vitesse and other controllers. when you step on the gas say 10%, the module send the computer a signal to open as if it were 14%. if you press 25% then the signal reads at 31%. its a linear curve of percentages more than what actual is, which is why cellsafemode pointed out, you can do the same with your foot. press faster.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant Last edited by PolynesianPowerhouse; 01-29-2017 at 06:05 PM. |
01-29-2017, 08:20 PM | #9 |
VTC!!!
01-30-2017, 08:29 AM | #10 |
What is VTC?
01-30-2017, 08:53 AM | #11 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
It's the Viteese controller mentioned above.
Kindness and compassion #OthersFirst |
01-30-2017, 10:00 AM | #12 |
Ah, I'll wait for the diablo tuner. Anyone know is we're getting one?
02-03-2017, 02:42 PM | #13 | |
Drives: 2x 94:Z28s - 2x95:Z28s - 1x16:1LT Join Date: Nov 2015
The Vitesse controller is simply the same thing except it doesnt alter the warranty, and is adjustable on the fly by a simple button press. I have had mine in for over a year with 0 issues. just unplug the peddle...and plug the controller in between. cant even see or feel it. |
02-03-2017, 08:10 PM | #14 | |
You can do absolutely everything a throttle controller can do with your foot on a stock car. All it's doing is manipulating the peddle position sensor. The tune is capable of actually correcting the issue rather than masking over it, along with everything else it is able to change. and yes, your Vitesse controller would alter the warranty if you were honest about using it and whatever you're trying to get covered can be proven to be related to the use of the unauthorized device. Granted, it's a much narrower scope if you fight the dealer than what a ecm/tcm tune could be responsible for, but as far as the warranty is concerned anything not authorized to be plugged or wired in by the OEM is suspect to voiding potential warranty work if related to the cause of the problem. |
