Old 01-25-2017, 12:25 PM   #1
osubuckeye
osubuckeye's Avatar
Drives: 2016 2LT Gamet Red Tintcoat
Transmission Turbine Shaft Recall
Anyone else get this recall. When I took my Camaro to the dealership today for it's annual oil & filter change they told me there was a recall (33110) against my car. The recall bulletin says 8-speed transmission turbine shaft fracture reprogrammed transmission control module per recall 33110.
I didn't get any notification from GM and my Chevrolet Owner Center Account also shows no recalls for my car. I can't find any information on this issue.
osubuckeye is offline   Reply With Quote
Old 01-25-2017, 12:39 PM   #2
qnhouston
Drives: 2LT GAZ H0Y IO6 LGX MX0 RIK WRS ZN2
It was done on mine. This is what I have for information.
Field Action Details
Type Number Description Release Date
Service Update Bulletins 2033110 8-Speed Transmission Turbine Shaft Failure 09/16/2016
Status: Closed
Group:
Sub-Group: 92949
Expires: Does not expire
Original Number: 33110
Labour Ops: 9102565 203311 - Transmission Control Module Reprogramming with SPS
Government Agency #:
Field Action Description: When a commanded shift occurs outside of the expected transmission turbine speed window limits, the commanded shift monitor requests a driver defaulted 8th gear state. The torque associated with the default action results in broken turbine shaft. The calibration window (based on output speed) for the safety monitor (P16F3) is smaller than the calibration window for the driver initiated TAP downshift speed limit checks.
Safety Risk Description:
Repair Description: Reprogram the Transmission Control Module.
qnhouston is offline   Reply With Quote
Old 01-25-2017, 08:38 PM   #3
cigarfan
cigarfan's Avatar
Drives: 16' Camaro 2/SS BlackMosaic A/8 NPP
https://my.gm.com/recalls
Checked my VIN...no recall. Besides, have had 2 recalls this past year. Hoping for no more.
cigarfan is offline   Reply With Quote
Old 01-25-2017, 10:53 PM   #4
laynlo15
Drives: 2022 Lt1 A10
None for me either
Old 01-26-2017, 08:57 AM   #5
osubuckeye
osubuckeye's Avatar
What worries me is that when I enter my VIN in the GM Recall Center Site it says there are no recalls against my VIN so why did my dealer tell me my car was subject to this recall.
Old 01-26-2017, 09:01 AM   #6
KMPrenger
KMPrenger's Avatar
So I notice the two folks in this thread that had it done are LT owners. The ones saying they couldn't find the recall are SS owners.
I'm assuming that's the difference that accounts for why the SS owners aren't seeing the recall.
Old 01-26-2017, 09:30 AM   #7
wavsine
________/\_
wavsine's Avatar
Drives: Gen6 NGM RS
Send a message via Yahoo to wavsine
Bulletin 2033110 is a field action which is not technically a recall.
I have an LT and my car does not show up on the GM website when I input the VIN. Build date 4/2016.
It may be that only recalls show up on the GM website, not field service actions. If that is the case, SS owners would have to check with their dealer to see if their car is included in this field action.
wavsine is offline   Reply With Quote
Old 01-26-2017, 07:03 PM   #8
cigarfan
cigarfan's Avatar
Status: Closed
Group:
Sub-Group: 92949
Labour Ops: 9102565 203311 - Trans/mission Control Module Reprogramming with SPS
My question is when was your work done...9/16?
Or was this bulletin issued on such date?
My car was in for transmission line recall 3 weeks ago.
Dealer would of said something...but then again
Old 01-26-2017, 07:38 PM   #9
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
if you dont use your paddle shifters, you are probably fine since that's how you trigger the software bug that they are fixing with the programming update.
Pretty sure it only affects the 8L45 transmission (not the auto in the V8).
if you have no broken the turbine, you'll just get a flash update.
Old 01-26-2017, 08:55 PM   #10
wavsine
________/\_
wavsine's Avatar
Drives: Gen6 NGM RS
I have the 8L45 tranny in a 2016 1LT. Build date 4/4/2016. I called my dealer and they ran the VIN. No recalls and no field service actions on my car.
Old 01-27-2017, 03:09 AM   #11
qnhouston
9/16 was the bulletin date.
i purchased my car on 10/20 and running a Investigate History at the dealer showed that there were two field actions. They were performed prior to me taking the car. I work at the dealer and it is standard practice to ensure all Field Actions and Recalls are performed prior to delivery. Federal law requires Recalls to be done prior to sale. Field Actions do not.
Old 02-16-2017, 11:26 AM   #12
MarkZ
MarkZ's Avatar
Drives: 2016 Camaro RS 2LT
My service writer today called it a recall. It popped up in his computer automatically, said it had to be done. Not sure if his terminology was correct, but those were his words.
Mark
MarkZ is offline   Reply With Quote
Old 02-19-2017, 10:02 PM   #13
MarkZ
MarkZ's Avatar
FWIW: Invoice from dealer refers to it as a recall.
Mark
Old 03-29-2019, 09:03 PM   #14
wjmeyer
wjmeyer's Avatar
Drives: 2016 Camaro RS, 2LT
It showed up on the service guy's computer when I brought in my car for the A8 shudder problem, they will fix both items. He said it (Transmission Turbine Shaft issue) is only covered by the 3-year warranty period, weird!! The A8 shudder problem is covered by the 5-year powertrain warranty. It would be nice if GM would send me a postcard!
wjmeyer is offline   Reply With Quote
