Old 01-23-2017, 01:45 PM   #1
Blazin383
Blazin383's Avatar
Drives: 2016 SS
For those who use a Battery Tender
For you guys that have your cars on a battery tender for the winter, how are you connecting the tender? Via the under hood jumper terminal, or directly to the battery.
Blazin383 is offline   Reply With Quote
Old 01-23-2017, 01:53 PM   #2
tcal780
tcal780's Avatar
Drives: 16 1SS White M6
Under the hood.
I snuck the wires up from the bottom through the hood latch area so I can keep the hood closed and the cover on.
tcal780 is offline   Reply With Quote
Old 01-23-2017, 02:03 PM   #3
Mighunter
Drives: 2017 Summit White 2SS
I pulled the stuff hiding the battery in the trunk aside and hooked it up there.
Mighunter is offline   Reply With Quote
Old 01-23-2017, 02:13 PM   #4
I`m Batman
I`m Batman's Avatar
Drives: 2016 Camaro SS M6
I hooked it up directly to the battery in the trunk. If you run your wire correctly, you can easily close the trunk without pinching the wires.
I`m Batman is offline   Reply With Quote
Old 01-23-2017, 02:16 PM   #5
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Well, isn't there a tender LPO option? Where do they say to hook it up? it really shouldn't matter, but using the terminals under the hood would seem far more convenient.
Old 01-23-2017, 02:38 PM   #6
slather
Drives: 2017 Camaro 2SS convertible
Under the hood.
slather is offline   Reply With Quote
Old 01-23-2017, 02:40 PM   #7
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
like others... Under the hood. on the fuse block there is a red terminal. I use that and a ground terminal that connects to the front frame like just before the fuse block.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 01-23-2017, 02:42 PM   #8
Drags1998
Drives: 15 SilveradoLTZ,162SSVert BlazerRS
Mine is hooked up to the Terminals under the hood. Wires running through the grill, I would not put the charger in the Trunk! Running the wires into the trunk is OK, I just don't trust ANY charger INSIDE the car anywhere.
Drags1998 is offline   Reply With Quote
Old 01-23-2017, 02:45 PM   #9
Grandpawmoses
Grandpawmoses's Avatar
Drives: 2017 2SS 50th Anniversary
In the trunk, directly to the battery. Just personal preference but only with the ring terminal pigtail, never with the alligator clip pigtail.
Grandpawmoses is offline   Reply With Quote
Old 01-23-2017, 02:53 PM   #10
jwober
jwober's Avatar
Drives: 50th Anniversary 2SS M6 Convertible
Negative under the negative jump post and positive on a spare "hot" stud under the "under hood electrical box" cover using the eyelets, run through a grille opening
2017 2SS M6 H50 Convertible 1 of 158
1100 8/05/16 | 2000 8/08/16
3000 8/10/16 | TPW 9/5/16 8/13/16
3100 8/26/16 | 3300 8/30/16
3400 8/31/16 | 3800 9/8/16 PS#2293
4B00 9/10/16 | 4200 9/13/16
5000 & 6000 9/14/16
jwober is offline   Reply With Quote
Old 01-23-2017, 04:11 PM   #11
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
In the trunk, directly to the battery. Using the ring terminal pigtail with extension cable. The tender sits outside the car. When ready to take out in the spring just disconnect pigtail at battery and tuck behind panel.
CTEK 56-304-1 Comfort Connect Extension Cable, 8.2 Feet
CTEK (56-158) MULTI US 3300 12 Volt Fully Automatic 4 step Battery Charger
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 01-23-2017, 05:39 PM   #12
toro1966
toro1966's Avatar
Drives: 2017 Camaro SS Convertible 50th
Under hood directly to terminals (red under the plastic cap and the specific ground stud attached to support).
I have the "Camaro" one that I had the dealer throw in when I bought the car. I run the wires up through the cowl up front and out near the windshield wipers. Fits great and I can close the hood no problem.
toro1966 is offline   Reply With Quote
Old 01-23-2017, 05:49 PM   #13
Miller79
Miller79's Avatar
Drives: '17 Camaro 1SS
Hooked mine back up today, now that the unseasonably warm spell is over. I have the "brain" resting above the passenger wiper blade with a towel underneath. The wires run under the closed hood to the terminals described above. The plug runs down the outside of the fender with another towel protecting the paint. There's enough play in my car cover even with the tie-down cord attached that the tender plugs into the wall without touching the floor.
2017 1SS Hyper Blue w/ White Rally Stripes
Order #TVGVN7
Ordered: 10/12/16 Built: 11/09/16
Finally picked up: 12/14/16
Miller79 is offline   Reply With Quote
Old 01-23-2017, 06:02 PM   #14
toro1966
toro1966's Avatar
This is literally exactly how mine is - down to the towels
