Old 01-22-2017, 08:25 PM   #1
glovo
Drives: Camaro 2016 1LT RS
How to play music in the camaro with the car off?
On the 2016 camaro when the car is off the music turns off after a couple minutes and it's annoying. I've tried with they key inside or outside, either with close door or open and nothing.
Has anybody find a way to listen to music with the car off?
glovo is offline   Reply With Quote
Old 01-22-2017, 08:32 PM   #2
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
press and hold the ignition button about 8 seconds.. that's like clicking your key to the acc in the old days.. Don't step on the brake.. just press the button and the green ring light will come on. good to go
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 01-23-2017, 01:33 AM   #3
GTIanZ28
Drives: 2016 V6 RS Camaro 6MT
Just hit the stereo power button and you'll get 10 minutes of radio play. When it shuts off hit the stereo power button again. Key has to be in the car.
The other option with a manual trans is to hit the start button without the clutch depressed. Perhaps different with an auto trans.
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
GTIanZ28 is offline   Reply With Quote
Old 01-23-2017, 03:53 AM   #4
Driski
Drives: 2016 Camaro Convertible 2SS
This is a great question... went to the drive in last summer and couldn't figure it out! Did not plan on going back because it was such a hassle.
Seems pretty simple... Thank you!
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85
Driski is offline   Reply With Quote
Old 01-23-2017, 06:37 AM   #5
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
Reading the owners manual seems to be an issue for some.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 01-23-2017, 06:38 AM   #6
glovo
For real ? Gonna try this thanks
Old 01-23-2017, 07:32 AM   #7
ron scubadiver
Drives: 2017 2SS Hyper Blue
Learn to play the flute.
ron scubadiver is offline   Reply With Quote
Old 01-23-2017, 08:11 AM   #8
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
This is called "service mode". Turns on all vehicle electronics, including the stereo, until you turn them off again.
Beware - it will drain your battery quicker than accessory mode or hitting the radio button over and over again. Just keep an eye on things.
Old 01-23-2017, 08:26 PM   #9
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
The owners manual is pretty informative.
dpevans is offline   Reply With Quote
Old 01-23-2017, 10:54 PM   #10
mekirk2
mekirk2's Avatar
Drives: 2016 2SS Ragtop Garnet Red
Exactly - like turning your key to the 'run' position, not the 'acc' position.
mekirk2 is offline   Reply With Quote
Old 01-24-2017, 10:50 AM   #11
TJay74
The radio has additional 10 minute extensions by pressing the power button, I was told GM calls this garage mode. That is all I use on mine, the wifes Audi works the same way as well.
Old 01-25-2017, 08:05 PM   #12
glovo
Holding the button works perfect finally I can listen to music longer, it does leaves ever light on so that's okay with me
Old 01-26-2017, 11:01 AM   #13
HDRDTD
Be careful just how long you leave the radio on. Last summer I left the radio playing at a low level while I polished/waxed my 2013 ZL1, took about 5 hours.
tried to start the car afterwards, but no luck. Let the car sit for an hour, then it would start.
Old 01-27-2017, 11:57 AM   #14
TJay74
you don't want to put it on the start mode, it will turn on every module in the car while it is in that mode. Either push the radio button to get the additional 10 minutes or put it in accessory mode.
