Old 01-22-2017, 10:43 AM   #1
SilverSixGen
SilverSixGen's Avatar
Drives: 2016 Camaro SS
New owner question...
How do I know whether or not I have the NPP exhaust of my 2016 Camaro ss? Its a 1ss if that helps. Sorry if it seems like a dumb question.
SilverSixGen is offline   Reply With Quote
Old 01-22-2017, 10:45 AM   #2
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Do you have 2 exhaust tips or 4? 4 is NPP.
Old 01-22-2017, 10:46 AM   #3
1LE801
"Lohla"
1LE801's Avatar
Drives: 2016 1SS A8 :"Lohla"
4 exhaust tips = NPP
2 = not NPP
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
1LE801 is offline   Reply With Quote
Old 01-22-2017, 10:49 AM   #4
CyberGuyPR
CyberGuyPR's Avatar
Drives: '16 vert 2LT RS NPP
As said above, quad tips. Windows sticker should also specify options.
CyberGuyPR is offline   Reply With Quote
Old 01-22-2017, 10:50 AM   #5
1LE801
"Lohla"
1LE801's Avatar
On the 1SS and 2SS the NPP is still optional I think....
Old 01-22-2017, 11:10 AM   #6
SilverSixGen
Thanks guys! I have quad tips and I was looking into getting headers but I don't want the NPP exhaust so I have to figure out my options.
Old 01-22-2017, 11:27 AM   #7
BravoMyles
BravoMyles's Avatar
Drives: Blue/Black 2017 1SS
NPP sounds great with headers. Here's mine with heads, cam, and full bolt ons into the NPP muffler.
https://www.instagram.com/p/BPjELJqh...-by=bravomyles
2017 1SS - Hyper Blue Metallic
Heads, Cam, e85, 3600 Stall, Full bolt-ons, MBRP exhaust
2010 2SS - Summit White - SOLD
CAI intake, Borla Atak axle-back (Summit xpipe resonator delete), custom ported TB, Texas Speed 1 7/8" LT Headers w/ Catless connections
Instagram: bravomyles
BravoMyles is offline   Reply With Quote
Old 01-22-2017, 11:37 AM   #8
1LE801
"Lohla"
1LE801's Avatar
NPP is legit! Check it out with longtubes https://youtu.be/FOgFDrh5Otw
Old 01-22-2017, 11:46 AM   #9
1LE801
"Lohla"
1LE801's Avatar
Uno mas https://youtu.be/YnAKrmrO5Xg
Old 01-22-2017, 12:14 PM   #10
SilverSixGen
If I get LT headers and wanna bypass the NPP set up could I just connect the LT's to a x pipe then to the NPP system and pull the fuse?
Old 01-22-2017, 12:17 PM   #11
1LE801
"Lohla"
1LE801's Avatar
I think so. I have considered pulling my fuse but cold starts are LOUD. I usually put the car in stealth mode if I'm starting it early in the morning, out of mercy for my neighbors. I LOVE having the ability to control my noise level. Just my .02.
Old 01-22-2017, 12:17 PM   #12
BravoMyles
BravoMyles's Avatar
Pulling the fuse will leave the NPP open all the time, that's what I did. So it won't close up at cruise speeds. Stainless Works long tubes come with the x-pipe you mention, mine go all the way back to the NPP muffler. You're not bypassing the NPP exactly, but instead just using it for the loud setting and disabling the valves so it STAYS in loud mode. In my opinion, keep the NPP and get the Stainless Works headers, pull the NPP fuse and enjoy. If you swap NPP for another exhaust, you're just spending extra money when it isn't necessary.
Old 01-22-2017, 01:01 PM   #13
tecmec
tecmec's Avatar
Drives: 2016 2SS
No matter what mode you're in, it starts with the valve open. NPP wont quiet down your starts, stealth mode or not.
tecmec is offline   Reply With Quote
Old 01-22-2017, 01:02 PM   #14
1LE801
"Lohla"
1LE801's Avatar
Originally Posted by tecmec View Post
No matter what mode you're in, it starts with the valve open. NPP wont quiet down your starts.
Negative. Starting in stealth, they are closed. Know this for a fact. All other modes start open.
