Old 01-21-2017, 03:33 PM   #1
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Maggie tune cause steering issues??
I am not sure where to stick this, I created a thread over in the issue's thread. I would assume that the magnuson tune won't affect any of the steering? or just the fuel/engine part of it? here is what I said in the other thread. reason why I posted here also, is none of this was happening prior to the install.
So after I added my supercharger, I had not driven it due to the weather,. It has been sitting under the blanket until today. I finally had a chance to stretch its legs and under 3 instances a warning message. I was pulling out of a parking lot, got the message and the steering wheel went dead. another is when I finally floored it and I got the message but about a second later it went away. The third is when I was going around the corner. lost the steering, then came back right away. This could easily cause an accident if I were not ready for it or in a bind somehow.
has any of you experienced this? I would assume this would be related to the charger install. but we did not touch anything with the steering, so not sure on that. could it be due to the tune? I would assume the tune has nothing to do with the steering.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 01-21-2017, 04:25 PM   #2
SSFanboy
SSFanboy's Avatar
Drives: 2016 Camaro A8 2SS w/Maggie
If you're running the Magnuson warranted tune, there's no way it's the cause of your issue. If you have a custom tune...maybe, but I doubt it. You should immediately go to your local Chevy dealership and have them take a look, because that is VERY dangerous. You might consider having it towed there. If the steering condition threw a code, they'll find it and determine root cause.
SSFanboy is offline   Reply With Quote
Old 01-21-2017, 05:23 PM   #3
laynlo15
Drives: 2022 Lt1 A10
That's a GM issue, its electric steering and has nothing to do with the tune.
Old 01-22-2017, 11:48 AM   #4
ADM PERFORMANCE
Drives: Anything I want
Its a known problem with all GM EPS cars.
Read our data here as well as some good articles -
http://www.camaro5.com/forums/showthread.php?t=417367
ADM PERFORMANCE is offline   Reply With Quote
Old 01-22-2017, 12:15 PM   #5
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
Is this still a problem? You would think they would have fixed this.
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 01-22-2017, 12:34 PM   #6
toohighpsi
Drives: 2015 C7 Z06 M7
The Cal cannot effect the steering system (different ECU).
Did you make sure the fuel line was properly secured to the firewall to prevent it contacting the engine wiring harness. Please see page 52 of the Magnuson installation manual and verify this step was performed correctly.
http://www.magnusonsuperchargers.com..._Camaro_DI.pdf
Old 01-23-2017, 12:47 PM   #7
oneredry
HYPER SS
oneredry's Avatar
yeah did all that. I drove it around yesterday and didn't notice any more lights. (not that I'm throwing it to the side) but if it does it again. I'm just going to have to bite the bullet and take it to the dealer.
Ordered: 1/15/2016
Delivered 03/23/16
