![]() Drives: 2017 SS 1LE Join Date: Dec 2016
Torque Specs???
So after flipping through my manual and looking on here and google I could not find a torque spec reference sheet. Looking for something that lists oil drain bolt, wheels etc. Thank you in advance and sorry if I missed it here!
'17 SS 1LE Summit White 6M
Stainless Works Cat Back, Roto Fab Intake, Catch Can |
![]() Drives: 2017 2SS Join Date: Jun 2014
Just do what the local tire replacement shops do.
Find the biggest, strongest guy in the shop. Then give him a 6-foot-long breaker bar, and tell him to tighten the lug nuts as much as possible. If you don't have a guy like that around, just weld the lug nuts on the bolts. It'll take around the same effort to remove. |
#3 | |
![]() Drives: 2017 2SS Join Date: Jul 2015
I'll ask the shop and see if i can get back to you on that one. |
Service adviser here at my dealership says 100ft/lbs. for the wheels, the oil drain bolt is just snug, no real specs for it.
![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS/1LE Join Date: Sep 2016
Lug nuts are 140 lb/ft (pg 352). Not sure about oil drain plug.
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Wow, 140 ft lbs for the lug nuts?
#7 |
#8 |
Yep, the wheel lugs get 140 pounds, fun fun fun...
An aside: if you haven't checked the torque on your factory wheels lug nuts, do it. I had 650 miles on my factory wheels when I jacked up the car to install my MRR wheels. The factory lug nuts came of VERY easily on 2 of the 4 wheels. If I had to guess, I'd estimate that they had 60-65 pounds of torque on them. |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: S O L D Join Date: Aug 2016
Yes. I know it is high, but 140 is the correct spec.. I also confirmed it prior to buying a torque limiter stick for my air tool.
Club F1FTY
2017 2SS 50th Anniversary Convertible Borla S-Type exhaust NPP| GM CAI | Color matched GM side skirts | Color matched 3rd brake light | Big Worm Graphics smoked out tail lights & rear reflectors | Oracle ghosted side markers | LED License plate bulbs | Door striker covers | Jam handle | Engine emblems from RiverCity Creations | 50th Center Console | Black bow ties | Hawk Performance ceramic brake pads | ZL1 Start button | CQuartz ceramic paint finish | Novistretch bra | S O L D |
#10 |
Thanks for the reply's guys! Guess i'll just wing it on the other stuff. Hoping to find something like camaro 5 where they have everything listed out. I'm just OCD so I want everything as close to perfect as I can get lol.
#11 |
More information will come out once Helm releases the service manual. It's been pushed back numerous times, and was supposed to be released recently...
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS Join Date: Apr 2013
It's 140 ft-lbs on the 5th gen too, FWIW. Any semi well-seasoned worker at an auto shop won't bat an eye at this because if you've worked on modern cars, you know that many newer vehicles have a lug nut torque spec that was once reserved only for trucks. I definitely think it's overkill, but I think that's the desired outcome -- to ensure there's no way they come loose on their own. I had one shop torque mine to only about 90 and they eventually got a little looser until I tightened them myself correctly. That shop was a Pep Boys (yeah, don't ask. I was in a pinch and had a pre-balanced pre-mounted tire/wheel that just needed to go on, figured it was simple enough.)
#13 |
![]() Drives: 16 Hyper Blue RS V6 A8, 09 Civic EX Join Date: Jun 2016
#14 | |
マスタング = 遅い
