Old 01-15-2017, 11:01 AM   #1
RobertAvitia
BYND GARAGE
RobertAvitia's Avatar
Drives: 17' 1LT Turbo
Where Did I Go Wrong?
Yesterday was my free day so I decided to install my powered subwoofer (amp&push combo) I Researched all day and figure I'd take a crack at it but after I was finished with the installation, the amp wouldn't turn on. I have the line output converter connected to the yellow and blue wires from my factory amp, rca's connected to the amp witch turnes on once it gets an audio signal but I can't get the amp to turn on. I also tried useing a R.E.M. wire but still no audio signal. WHERE DID I GO WRONG???? (Non Bose car 1lt model)
RobertAvitia is offline   Reply With Quote
Old 01-15-2017, 11:17 AM   #2
HyperblueSS
HyperblueSS's Avatar
Drives: 2016 Camaro SS M6
Probably a bad connection. I don't really like using those clamp on splices personally.
2016 Hyperblue 1SS M6
"If you're not first you're last!"
HyperblueSS is offline   Reply With Quote
Old 01-15-2017, 11:29 AM   #3
RobertAvitia
BYND GARAGE
I don't either but it's what I had. Is everything wired correctly? Should I take the clamps off and hard wire the wires from the line converter to the wires from the amp?
Old 01-16-2017, 06:29 PM   #4
chris227
chris227's Avatar
Do not take your power and ground from the stock amp. Use the battery connections and there is a switched power fuse in the trunk fuse box. I personally didn't use a line out converter. just spliced a nice set of rca jacks and wired them to the wires on the stock amp.
