Old 01-13-2017, 04:16 PM   #1
NCSD
Drives: Nightfall, 2SS, A8, MRC, NPP,RE-71R
Trackday oil temps for SS
Now that the cars have been out for a while, what oil temps are your cars running at for trackdays?
What temp range is considered normal?
NCSD is offline   Reply With Quote
Old 01-13-2017, 11:14 PM   #2
mbar
Drives: 2016 1SS
I consistently get 230-240F. The oil temp gauge on the dash is not accurate. Used OBD2 to take temp.
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 01-14-2017, 09:29 AM   #3
DFW1LE
DFW1LE's Avatar
It might help if you indicated what conditions you are running under: your run times, the outside temperature, what oil you are running, etc. Recommended oils for tracking should be able to handle higher oil temperatures (e.g. 300 degrees).
Old 01-14-2017, 07:10 PM   #4
mbar
Drives: 2016 1SS
Originally Posted by NCSD View Post
Thanks MBAR ...Ok good, My oil showed 285 degrees on the dash gauge. I hope its wrong. What does the gauge on your dash show?
Dash showed around 285-290
