Old 01-13-2017, 02:31 PM   #1
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Upcoming Decision Tires/Wheels
Looking for some help and first hand knowledge from the Track and AutoX guys. I'm not a novice at either so don't give me the learn the car on the stock tires bs first. Plus this Callaway SS can spin the stock tires at almost 60mph on the street so it needs better rubber just for normal driving....
Ok my new Callaway SS needs some new meats for this upcoming season and these are the 2/3 options I am considering.
1. My original intention has always been to buy MRR 1LE replicas and throw on the 1LE/ZL1 rubber of 285/30R20 & 305/30R20 Goodyear Supercar 3s.
2. Recently been thinking about not purchasing wheels and just running the Bridgestone Potenza RE71Rs in 255/40R20 and 285/35R20.
3. If I could purchase a lightly used set of OEM 1LE wheels and tires I would gladly. Just missed out on the last set here on the forum.
Plans are roughly to run at least 4 HPDEs, 8 or so AutoXs, and 1 roll race event at Pocono Raceway. I've read mixed reviews about the RE71Rs road course ablility, but from what I've read they are hands down the best AutoX tire. Anybody have first hand experience to fill me in on? Basically not buying the MRRs will allow for another full set of RE71Rs to burn up, but if they will burn up twice as fast as the Supercar 3s and not perform better because of the smaller sizes then the cost savings becomes a moot point. Also have to consider the sale of the stock wheels and tires at probably around $800-$1000 which seems to be the going rate and drops the cost difference even more.
I do love the looks of the 1LE wheels so that is my preference in the looks department, but I don't dislike my stock black SS wheels so I don't need to change the look if it's not going to be worth it. Hopefully I explained myself enough here and you guys can give me some real world input.
The best ending to this thread would be if somebody sells me their OEM 1LE stuff!
Old 01-13-2017, 04:38 PM   #2
TheRealJA105
Drives: 2013 C6Z06
Let's hope someone can give us some feedback
Old 01-13-2017, 07:00 PM   #3
chandretti15
Drives: 2015 Summit White 1SS/1LE
I've run the RE-71Rs for 1 track day at Laguna Seca on my '15 1LE. They grip really well but wear fast. You can't really have both.
chandretti15 is offline   Reply With Quote
Old 01-13-2017, 08:26 PM   #4
MatthewAMEL
MatthewAMEL's Avatar
I have run Dunlop ZII SS, RE71R, NT05 and NT01 on track.
The NT01s were the best track tire, the RE71s the worst.
They are the best AutoX tire, but they cannot handle heat. They get hot, they get greasy and seem to dissolve between sessions.
I wasn't expecting much from the NT05, but I was pleasantly surprised by their dry grip and durability. They are also 'cheap'. Discount Tire's eBay store has some really good sales from time to time.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 01-14-2017, 07:43 PM   #5
mbar
Drives: 2016 1SS
I got the same feedback from friends at the track that RE71 is only for autoX.
I would also throw into the mix 255/285 Ventus RS3.
I'm exactly with the same dilemma : keep the stock rims or get a new dedicated set.
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 01-14-2017, 07:58 PM   #6
mbar
Drives: 2016 1SS
Which size would you run on gen6 Camaro ?
Old 01-15-2017, 09:03 AM   #7
MoreSpeed
MoreSpeed's Avatar
The RE71's seem to be THE tire for last years AutoX. While I have no experience with them at your sizes, they gained approximately a 2 second advantage (60 sec course) over Michelin Sport Cup 2's which had a tread wear of 180 verses the RE71's 200. With that tread wear, they should have been worse than the Michelin's. They were much, much better. They had the further advantage of being a stock class compatible tire verses the Michelin's which now move you to R class. This helped with PAX. They felt like almost like a cheater tire, running better than some 80 tread wear tires I had used in the past. Again - great autoX tire. They heat up quickly which is good for autoX. Heard not so great for track for reasons others listed above.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG
etc..
MoreSpeed is offline   Reply With Quote
Old 01-16-2017, 11:31 AM   #8
TheRealJA105
Drives: 2013 C6Z06
Good info guys! I had read a few other reviews that said they got too greasy for the track. I'll most likely be going with the Goodyears.
Old 01-16-2017, 12:33 PM   #9
TheRealJA105
Drives: 2013 C6Z06
Anybody know what seems to be the best 19" option for tires and rims for around the same sub $3000 price?
Old 01-18-2017, 07:30 PM   #10
Ls6larry
Ls6larry's Avatar
Drives: 94z28 03z06 05 gto 02ss 16ss
Therealja105 you can prob run some ford festiva wheels with spinner hub caps, I hurd they add 100hp and shave off 50lbs
Ls6larry is offline   Reply With Quote
Old 01-19-2017, 07:15 AM   #11
1LE801
"Lohla"
1LE801's Avatar
Drives: 2016 1SS A8 :"Lohla"
I run LG 5th Gen 1LE/ZL1 replicas. I have 315s in the back (6mm spacer needed) and 285s up front. The handling was transformed with this move. Also, do NOT get the eagle supercar g2s. They are excellent in corners but they leave a lot to be desired on acceleration in a SC car. Good luck, OP!!
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
1LE801 is offline   Reply With Quote
Old 01-19-2017, 07:47 AM   #12
TheRealJA105
Drives: 2013 C6Z06
I'm not looking at the G2s, I'm looking at the G3s, but what 315s are you running?
Old 01-19-2017, 07:57 AM   #13
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
What rubber? Pics?
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 01-19-2017, 01:27 PM   #14
TheRealJA105
Drives: 2013 C6Z06
How would you compare the NT05s to the Supercar 3s on the 1LE? The NT05s would be slightly cheaper but I would have to go 275/35 up front instead of 285/30 and they couldn't be rotated side to side without flipping around on the rims...
