![]() ![]() ![]() Drives: 2023 2SS Convertible Join Date: May 2009
Sub Box?
Anyone making one for the convertibles yet? It looks like there is room on the drivers side. I think the stereo needs a little boost.
-Geoff
![]() Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
AFAIK, there are no sub boxes made specifically for convertibles yet. However, there are off-the-shelf options available that will fit. The search function is your friend.
There's an example of something that will fit below the folded down top in this post.Another option is a footwell sub enclosure. Have you seen this thread?
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
Thank you. Not interested in either of those. Looking for a nice corner box made for my trunk. I had one like that on an old 4th gen and it worked great.
-Geoff
![]() Drives: 2016 SS Convertible Hyper Blue Join Date: Apr 2016
You will have to go custom for a corner box.
Blacked bow ties, full bigwormgraphix blackout
Gm splash guards Mishimoto catch can Black hash marks Curb alert Vitesse controller Jl audio HD 900/5 amp c5 650 components c2 650x coaxials rear fill 2 x 8" W3v3 subwoofers custom ported box Fix 82 module BF TPNS BF Wet Diamond BF Crystal Seal Hydr02 303 Aerospace top protectant |
I am sure somebody will make one at some point like they did for the 4th and 5th gen. I am very patient! Might play around with making my own too. I have a table saw and a mitre saw.
-Geoff
![]() Drives: 2017 FIFTY VERT MANUAL 2SS Join Date: Dec 2016
I had one made for the passenger foot well.
![]() It holds a 10" JL Sub, which is more than enough because it is in the passenger cabin and all the energy goes right to the driver and passenger. Sub in the trunk in a convertible loses so much because the sound just escapes especially when driving. |
#7 | |
-Geoff
#8 | |
![]() Drives: 2018 SS 1LE Join Date: Feb 2018
#9 |
![]() ![]() Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
I had to go custom , driver's side fiberglass enclosure. Single 10" JLW6. Sounds perfect with the top up. With the top down, loses a bit of umph though, as is to be expected. I think the passenger footwell would be a good place, if you can find a sub small enough and build a custom enclosure there. If you wait a bit, JL and others will likely make a stealth box that will fit, like they did for the 5th gen
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK ![]() |
#10 |
![]() Drives: 2017 2LT Garnet Red Join Date: Dec 2011
Hello all, I have been working on a sub box for my 2LT, and it will go under convertible top area, so when the top is up or down I hope to have powerful sub-bass. I am using 2 JL Audio 12TW3-D4 12" 400W Dual 4 Ohm Thin-Line Component Car Subwoofer wired as 2 ohm the as 1 ohm with a Rockford Fosgate Prime 1,200-Watt Class-D 1-Channel.
Using an M-650 Navtv so I get the flat sound from the 2017 Camaro Nav head unit, and a jl twk d8 for the sound control. The bass is not bad but now I am making a larger sub box that will provide a lower bass. If anyone wants more info on the box that I am making after I finish the build. Christopher |
#11 |
![]() Drives: 2022 2SS Vert in Wild Cherry Tint Join Date: Oct 2018
I would like to see the sub enclosure you did for top up or down.
