Drives: 2016 CAMARO SS/ gpi built Join Date: Dec 2014
GPI SS line of cam shafts for Gen 5 LT engines
I have been getting alot of intrerest in our GPI line of VVT cams and GPI cylinder heads. So here is a break down of our SS1LT-SS4LT cam shafts.
SS1LT- The SS1LT was designed with the daily driver in mind. It hits hard for a smaller cam shaft but also makes great power. The ss1lt is stock converter friendly. It has a nice idle and a smooth ride. Works great with our cylinder heads. We did a bolt on car with the ss1 heads, car put down 500 to the tires. SS2LT- The SS2LT cam packs more of a punch then the ss1 but still has some decent street manners on the stock converter. It will have a alittle push on the stock converter. This cam is great for the guy that hits the track once a month or so. I has a nice sharp chopping sound to it and is a great choice for the guy that doesnt want to invest in a converter right now but he can always add on later down the road. SS3LT- The SS3LT is for the street strip guy that is chasing a number at the track. With this cam you WILL need a aftermarket converter. This was the most popular cam when it comes to our LS cam cams and i expect the same out of this one. I would suggest a 3600 at up on a stall converter. This is one means ass street strip cam shaft! Will be a great compliment to our GPI cylinder heads. SS4LT- This is the baddest cam shaft we offer. This cam shaft has set many many recoreds on the LS side of the spectram. I will personally be running this cam shaft in my car this year. IT will require a 3800 and up stall converter. Fly cutting the top of the pistons IS NOT REQUIRED on the ss4 this time on unmilled heads. This is for the more serious racer and will be a full tilt boogie cam shaft. We also can custom cut a cam shaft to meet your specific build Now.. that being said, there is currently not a aftermarket converter out right now for the new 8 speed trans. I am currently testing a converter for a company and so far so good on that. last i heard he was looking around april to start production. When that is avalible you guys will the first to know and we will all be in business when it comes to the super aggressive stuff so definatly be on the look out of that. We look forward to building some badass Gen 6 cars and dominate just like we did with the gen 5 car Thanks from the entire team Gwatney Performance Innovations if you guys have any questions pm me or email josh@gogwatney.com |
![]() Drives: 2016 Chevy Camaro Join Date: Jun 2016
Top of the food chain cams....
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
poor experience and customer service with GPI, many other options.
just my .02 |
#4 | |
I looked at your site and the smaller cam can opt for .600 valve springs are the two smaller cams below .600 lift. Last question do I need to change the AFM lifters?
Josh, does the SS1 or SS2 have a 114+4 LSA? Going N/A on my build...
The SS1 is a .638 lift , around 224 duration. Not sure of anything on the SS2...
#7 |
#8 | |
#9 |
ill be posting up some specs on the cylinder heads in the next day or so. pm me about them so i can get you some answers.
#10 |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Audi TT RS Join Date: Jan 2014
Is the SS1LT a long term cam? I know you don't want to discuss specs but, with respect to the GM LT1 hot cam that came out not too long ago, the lift, ramp rate, etc. is fairly mild and is likely a cam that you don't have to change springs on every 25k miles or so.
Is this specced similarly? If so, that would make this attractive to buyers like myself who are not out to chase the big numbers but want to still enjoy having an aftermarket camshaft.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
#12 |
![]() Drives: 2002 Camaro SS Join Date: Jun 2012
Thanks for posting a breakdown.
2017 1SS Hyper Blue M6
2001 Ford Lightning |
#13 |
[QUOTE=USAFS197;9502766]Is the SS1LT a long term cam? I know you don't want to discuss specs but, with respect to the GM LT1 hot cam that came out not too long ago, the lift, ramp rate, etc. is fairly mild and is likely a cam that you don't have to change springs on every 25k miles or so.
Is this specced similarly? If so, that would make this attractive to buyers like myself who are not out to chase the big numbers but want to still enjoy having an aftermarket camshaft.[/QUOTE All our our cams lt and ls, will last a very long time with proper maintenance. The ss1lt will. Or shatter any record but will be a fantastic car shaft for the daily type of guy but it will also make really good numbers on the dyno. Cause let's face it that's what we all want when we invest thousands of dollars in our rides. Email me and I can discuss specs a little bit in detail with you |
#14 |
How would the ss1 or ss2 perform in a FI car? Or would you prefer to do a custom cam for a forced induction application?
