![]() Drives: Fast Join Date: Dec 2012
Overkill LGX Supercharger Development Thread
Hello everyone. Overkill Motorsport is in the process of developing a supercharger system for the 2016+ 3.6 Camaro and this is a thread that I'll be sharing pictures starting next week of the development process, sharing details of the kit and insight into the design.
For those to whom Overkill is not familiar, my name is Will, I'm the owner and head tuner for Overkill, my company specializes in V6 performance and I'm more well known on the 5th Gen Camaro V6 boards with tuning services and originating the 80mm throttle body and flex fuel kits (both coming for the 6th gen). A few details I can share right now on the kit are it should be very similar to our 5th Gen Camaro system shown below... ![]() You can see the aluminum crankshaft pulley above, shown in more detail below... ![]() That pulley delivers a dedicated 8-rib belt system to drive the supercharger and only the supercharger... ![]() The system will use a Vortech V3 supercharger unit, our CNC aluminum mounting brackets, an air to air front mounted intercooler system with blow off valve, and will include a catch can specifically designed for this supercharger system, as well as Overkill tuning services through a handheld Autocal tuning device. And here's the beautiful 2016 Camaro that the development will be done on... ![]() More to come! |
![]() Drives: NGM '16 2LT A8 Join Date: Feb 2014
I can't wait! I was actually contemplating on getting a V8 to mod due to the lack of aftermarket for the LGX. I look forward to doing business in the future!
![]() Drives: '16 Camaro 2LT RS Join Date: Aug 2015
Looking forward to seeing the progress!
![]() ![]() ![]() ![]() ![]() Drives: Gen 6 Camaro RS Join Date: Dec 2015
![]() ![]() Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
NICE! Wish I was in BC! Glad you decided to tackle this! Thanks Will
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
What's the price point you are shooting for?
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
#7 |
What are the power expectations?
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
This is very cool. I'm an SS owner but I was big into the V6 scene with my 2010 model. There was only one supercharger kit (my opinion) worth doing on that car, and that was the IPF kit. Past that there were turbo kits, but they all seemed to be very finicky and required constant maintenance. It was not something I would have done....I would have wanted a do once and done solution, and IPF was the only thing that seemed to hit that promise.
Hopefully this kit will be that way. Being a centrifugal setup it should provide lots of great top end power and great pull in the power band getting there, but those looking for ultimate low end grunt may not be as happy, as if a top mount solution was available. I don't consider this a bad thing as the car will still be screaming fast and will be easier on the stock drivetrain. I hope this works out well for you guys. V6 guys could use a few more bolt on type mods while your at it.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
#10 |
We'll post dyno numbers once completed. Our 5th gen LFX kit has no problems eclipsing 400 wheel horsepower and loves the boost, we hope the same or better out of the LGX. We'll be targetting around 8psi for a base kit and 10+ as an upgrade.
Pricing will depend on the parts required. Our 5th gen kit retails for $6499. There are some parts subtracted from the LGX kit but other parts undoubtly will need to be added before we're done with development. Here's my thread on the 5th gen kit http://www.camaro5.com/forums/showthread.php?t=472805 We'll have a top mount developed at a future date, but we'll need to see some hoods developed for the 6th gen that'll allow it to clear. |
#11 |
![]() ![]() Drives: ^^^This Join Date: Nov 2015
#12 |
I had a question about the vortech unit.
Have you done any testing using a smaller supercharger vs one that seems built for a V8 (website says the v3 makes over 700hp)? I ask because the bigger, bulkier supercharger is made to handle the strain and stress of 700+hp that it'll never see installed on the lgx. That sounds like a lot of wasted weight spinning around that doesn't need to be. Would you not potentially get more performance out of the lgx with a lighter and probably smaller supercharger? Price probably wouldn't be much different but the parasitic loss could be. Or does it end up not making any measurable difference? |
#13 |
STORM
Drives: 2021 Satin Steel Metallic 2SS Join Date: Jan 2016
I'm so excited! Time for that V6 Love...
#14 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
need some updates, want to see this work
