Old 01-11-2017, 10:51 AM   #1
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
DIY - stripes, lights, reflectors, tint, etc.
I've got my 2SS ordered. Build date is 2/13.
Rather than spend $695 to have red rally stripes done by the factory/dealership, I decided to buy the stripes and either install them myself or have them done. The shop that is going to do my window tint will put the stripes on for $200.
I'm wondering if anyone here has done them themselves?
I've put vinyl graphics on cars quite a bit. But, mostly 18" tall numbers and various other stickers for a racecar. These are much larger, and more involved. The instructions don't appear to be too difficult. However, the stripes are simply so large that I'm wary of trying to wrangle a 5' long stripe myself.
Any thoughts?
BTW, the details on this are:
CAR
- Mosaic black 2SS, 6-piston Brembos, black wheels, black bowties, red interior
ADDITIONS
- Red rally stripes
- Ghosted (black) side marker lights (appears black)
- 3rd brakelight blackout kit
- GM dark finish taillights
- Rear reflector blackout kit
Basically, trying to go with a complete black car, with red accents.
00 Trans Ram is offline   Reply With Quote
Old 01-11-2017, 09:43 PM   #2
Oramac2016
Oramac2016's Avatar
Drives: 2016 Camaro RS
Its all the same. Spray bottle with a lil soapy water.... then just take your time and dont rush it.
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
Oramac2016 is offline   Reply With Quote
Old 01-12-2017, 08:07 AM   #3
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
I did my own, custom, it took a while but satisfying. If they are pre-cut it should be easy.
Sent from my VS500 using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 01-12-2017, 08:28 AM   #4
00 Trans Ram
Drives: 2017 2SS
Good to know. So, it wasn't hard wrangling that large 5' section? How'd you do it?
I'm guessing:
- clean area with soap/water, then multiple passes with degreaser
- place vinyl where you want it
- mark that placement with masking tape
- remove vinyl
- remove backing paper and spray with soapy water
- spray car with soapy water
- place vinyl and begin light squeegee to get water out
- once stuck down, do more heavy squeegee to get water out
- remove top, protective layer of pre-mask
- do final squeegee (with squeegee covered by thin towel) to get last water/air bubbles out
Is that kinda close?
Old 01-12-2017, 08:48 AM   #5
sub_ETCS_ret
I'm guessing:
- remove vinyl
Mine was air release vinyl - No water required
-Clean and clay bar
-Isopropyl alcohol
-Since mine was custom I laid down the knifeless tape
-Isopropyl alcohol
-removed backing
-put one side down and pulled taut
-did my best to do a 4 corner pull (watched a few videos)
-used heat as necessary to stretch and heal
-pulled knifeless tape
I know this isn't exactly what you were looking for. sorry.
Old 01-12-2017, 08:54 AM   #6
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
It all depends what type of vinyl you have. Either wet or dry. If it's wet , the only thing I would add is when you're laying down those big pieces, A second set of hands really helps to initially position them. Then start squeegeeing
Old 01-12-2017, 09:36 AM   #7
00 Trans Ram
Drives: 2017 2SS
It's a wet vinyl. Directions are basically the above.
That 2nd set of hands is what I need - you're right.
