Old 01-10-2017, 06:48 PM   #1
BrandonBell
BrandonBell's Avatar
Drives: Hyper Blue Metalic gen 6
8A questions
So I'm kinda new to the forums still but I have been researching heads cam headers and a bottle, that said I was curious what's the limits of the 8 speed auto and rear ends in the 16 ss? Thanks for the time guys
BrandonBell is offline   Reply With Quote
Old 01-10-2017, 06:53 PM   #2
Hard Parker
Hard Parker's Avatar
Drives: ZL1
A8 is still new tech
I have heard rear ends are stronger than 5th gen SS's
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 01-10-2017, 08:10 PM   #3
BrandonBell
Thanks parker, anybody know at what point with the cam that a stall would be needed?
Old 01-10-2017, 10:40 PM   #4
Hard Parker
Drives: ZL1
Depends on how aggressive....stall gonna help period
#savethemanuals
Old 01-10-2017, 11:01 PM   #5
Blk16SS
Blk16SS's Avatar
Drives: 2016 Chevy Camaro
In most cases with this car less is more.. You never stated your intended use , I.E., mostly track, occasional track, or no track at all, so its hard to answer your questions. Cam-wise, most stage 1 cams that are offered by every vendor you can think of will work perfectly and give the results you're looking for. I've yet to see what I would call a bad cam. They all have their intended use, that's why its up to the owner to ask questions when it comes to cams. Converter-wise, unless its gonna be at the track quite a bit with slicks, it would be the very last mod on my list if at all. Not worth the hassle. ..
Blk16SS is offline   Reply With Quote
Old 01-10-2017, 11:02 PM   #6
Hard Parker
Drives: ZL1
^^^^pretty much
#savethemanuals
