![]() Drives: 2017 Camaro 1 SS Join Date: Jun 2016
Weight difference...1SS vs. 2SS.
I know it's probably splitting hairs, but just out of curiosity...does anyone know if there's any weight difference between a fully loaded 2SS and a stripped down 1SS?
50lbs? 100lbs? 200lbs?
1SS - M6 - Silver Ice Metallic - Dual Mode Exhaust. Light, Simple, Fast. "If everything's under control, you're going too slow" - Mario Andretti Last edited by Canyon Carver; 01-10-2017 at 02:46 PM. Reason: fix formatting |
![]() ![]() Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
50-80lbs I believe. My 1SS with MRC weighed 3700lbs with a half tank of gas.
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS M6, NPP Join Date: Apr 2016
#4 | |
1SS - M6 - Silver Ice Metallic - Dual Mode Exhaust. Light, Simple, Fast. "If everything's under control, you're going too slow" - Mario Andretti |
#5 | |
SLO 1SS - sold
GM claims 3680 lbs for a 1SS but now sure how much fuel is in.. if you're had 1/8 of fuel which is almost empty, @ ~7-8 lbs per gallon then it will be around 3610-3640 lbs?
Not all weight scale is equal so let's just say +-10 lbs or so as a guesstimate if that. |
#7 |
How is that? If your 1SS weighs 3700 lbs with a half tank of gas and his 1SS (I'm pretty sure he has a 1SS)) weighs 3589 with 1/8 tank - how is that 200 lbs. different? Its more like 60 - 70 lbs in difference when you factor in the gas weight difference which probably is within the margin of error for the scales you each used.
#8 |
I think the M6 will be lighter then my A8. At the LS fest mine weighed 3665 with a 1/4 tank of fuel. I'm not sure what extras the 2ss will have that adds weight, seats might be a little heavier with the leather. I don't know how much MRC adds either, but all 2ss models don't have that either.
#9 | |
Looking back I took the curb weight of car and drivers test, which was a 2SS now that I think of it, and they say 3760. Right around 200lbs. My mistake, I assumed they tested a 1SS. With an 1/8 tank my car would weigh 3675 on the same scale. His car weighed 3575. I think 100 lbs is a little outside of margin of error especially when I weighed the car on a commercial scale and those guys are sticklers.
SLO 1SS - sold
#10 |
Check me out on YouTube!
Drives: 2016 Camaro SS Join Date: Feb 2015
I have a my 2SS (sunroof, leather, A8).
Just over a half tank on a semi-truck scale, it was 3700. On a friend's calibrated race scales, with just a couple gallons in it, it was 3650.
2016 Camaro SS - A8, NPP, 2SS, Nightfall Gray Metallic
11.68 @ 118 - CAI Intake - TSP 2" Longtubes - DSX Tuning Flex Fuel - DSX Tuned 11.91 @ 117 - CAI intake only 11.99 @ 117 - STOCK 1/4 mile 410 RWHP / 424 RWTQ - STOCK Dyno --- YouTube Channel: BadBowtieProductions |
#11 | |
![]() Drives: 2018 Hyperblue Camaro 1SS/1LE Join Date: Feb 2015
With everything base and m6... the vin sticker on my car says 3,4XX (the XX being two numbers I can't remember) |
#12 |
![]() Drives: 2019 ZL1 1LE Join Date: Sep 2010
My 1SS with NPP on 19" Forgestars and 1/3rd tank of fuel was 3569 on race scales. When I removed the tow hook from the trunk it was 3567, heh.
#13 |
![]() ![]() Drives: 2019 Shock ZL1 Join Date: Jan 2007
From the 2017 order guide specs section, both a 1SS and 2SS M6 clock in at a base curb weight of 3685lbs, and the 1SS and 2SS A8 clock in at 3697lbs. 1LE base curbs at 3747lbs.
http://www.gmfleetorderguide.com/NAS...&page=&butID=9
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
#14 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
I think the 2SS weighs as much as a 1LE so about 60-80 lbs difference.
