Old 01-08-2017, 02:01 PM   #1
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
Just Curious - NA to equal SC
I was just curious about what it would take mechanically for a NA car to achieve the same RWHP results of a SCd car such as a Maggie with a canned tune. Not looking at race fuel or e85.
Sent from my SM-G920V using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 01-08-2017, 02:27 PM   #2
Blk16SS
Blk16SS's Avatar
Drives: 2016 Chevy Camaro
Plz be a bit more specific. Are you referring to HP or ET? And are we using the same $8-10k spent on a blower or is there no budget at all?
Blk16SS is offline   Reply With Quote
Old 01-08-2017, 02:35 PM   #3
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
Define results...
Dyno numbers or win/loss street/track?
EFI Tuning is offline   Reply With Quote
Old 01-08-2017, 03:06 PM   #4
sub_ETCS_ret
Sorry - RWHP. Let's say 550 without e85, race fuel, or additives if possible. Just purely mechanical.
Old 01-08-2017, 03:07 PM   #5
sub_ETCS_ret
Budget not a consideration.
Old 01-08-2017, 03:25 PM   #6
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
416 / 427.
Old 01-08-2017, 03:28 PM   #7
Blk16SS
Blk16SS's Avatar
Its possible with the right heads and cam. A 416ci is not needed to get you there, but I am big fan of cubic inches. Far more than a blower...
Old 01-08-2017, 03:30 PM   #8
sub_ETCS_ret
416 / 427.
So you're saying that those cubes will get you to 550?
Old 01-08-2017, 03:31 PM   #9
Blk16SS
Blk16SS's Avatar
Yes.... This is a quote from a leading vendor..
Old 01-08-2017, 03:32 PM   #10
sub_ETCS_ret
What site did you pull that down from?
Old 01-08-2017, 03:35 PM   #11
Blk16SS
Blk16SS's Avatar
PM me ... I respectfully won't endorse vendors publicly....
Old 01-08-2017, 03:37 PM   #12
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Sub_ETCS_ret you have been doing some serious researching before you make a purchase. My ultimate goal was 550, still hoping I can get there with e85, exhaust mods down the line, etc..
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 01-08-2017, 03:38 PM   #13
Blk16SS
Blk16SS's Avatar
I also stress that a custom race valve job is worth its weight in the performance world... Its a small detail that gets overlooked a lot...
Old 01-08-2017, 03:43 PM   #14
oldman
Drives: SS 6 speed of course
416 / 427.
yep budget no problem:
Katech’s engine made 703 hp at 6,800 rpm and 625 lb-ft of torque at 5,200 rpm, compared to Chevrolet’s supercharged LT4’s 650 hp. It’s also nearly 55 percent greater output than the LT1’s standard 455hp output. We should qualify the numbers here by pointing out Katech’s LT1 numbers were factored with STP correction math and Chevrolet’s official power numbers use a SAE correction factor to produce the output number. That means Katech’s numbers are higher than they would be with comparable SAE correction—perhaps around 4 percent.
