Old 01-06-2017, 04:17 PM   #1
aa406079
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6
Anyone running a lightweight battery on their Daily Driver?
I have been reading a bunch about this battery
https://www.amazon.com/dp/B0002ILK6I...ing=UTF8&psc=1
15 lbs seems fairly stout.... ( stock batteries are 40-45 lbs)
however most of the forums that discuss this are import drivers... wonder if this thing can handle cranking over a 6.2 L V8....
Thoughts?
aa406079 is offline   Reply With Quote
Old 01-06-2017, 04:43 PM   #2
Captain Slow
Drives: 2017 SS
I've had a bunch of those in different cars.
Been using one in my 02 SS for years. It rarely gets driven and I haven't even had to put a battery tender on it.
Edit: I see you're in Alberta/BC. Not sure how well it'll do up there if it's your winter DD.
Captain Slow is offline   Reply With Quote
Old 01-06-2017, 09:40 PM   #3
Snowblind
Snowblind's Avatar
Thoughts?
I tried that exact one and it doesn't have enough amps to crank it once it is warmed up. I've run this 21 lb. Duracell before winter came and I had zero issues.
Old 01-06-2017, 10:37 PM   #4
oldman
Drives: SS 6 speed of course
i run them in my 2 DD Honda autoXcars. Snow how much weight savings?
Old 01-07-2017, 08:29 AM   #5
Snowblind
Snowblind's Avatar
It sheds 24 lbs.
http://www.camaro6.com/forums/showth...weight+battery
Old 01-07-2017, 08:40 AM   #6
MuhThugga
Poppycock
Drives: Pontiac GTO
That thing has only 170 cold cranking amps. It is not going to like starting in the winter months.
MuhThugga is offline   Reply With Quote
