Old 01-03-2017, 10:19 PM   #1
Quiksilver16ss
Quiksilver16ss's Avatar
Drives: 2016 camaro 1ss
Lowest MPH in 6th gear without lugging?
Was wondering what's the lowest speed everyone is going in 6th gear in an SS M6 without dangerously lugging the motor too low in RPMs? Me 50 is the lowest.
2016 Camaro 1SS
M6, NPP, MRC, sunroof, black hashmarks, black bowties, Low gloss black 20" wheels
Quiksilver16ss is offline   Reply With Quote
Old 01-04-2017, 11:11 AM   #2
Lemosine
Lemosine's Avatar
Drives: 2016 M6 Hyper Blue 2SS
I would say 60
Lemosine is offline   Reply With Quote
Old 01-04-2017, 12:02 PM   #3
Mityguy
Drives: 2018 Hyperblue Camaro 1SS/1LE
50 seems really slow for 6th... I'd say the lowest speed i'm willing to shift in to sixth is 60.
Mityguy is offline   Reply With Quote
Old 01-04-2017, 12:09 PM   #4
diirk
diirk's Avatar
Drives: 2016 Camaro SS
I'm around 55mph. I typically just go by RPM. I shift into 6th at 2k when I'm playing with trying to get better mileage.
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad
91 Miata 1.8 Feal Wilwood Track Car
1morproject
diirk is offline   Reply With Quote
Old 01-04-2017, 12:15 PM   #5
4xlr8n
Red Hot
4xlr8n's Avatar
Drives: 2017 Camaro RS
The answer is...it depends...
Lugging is a product of two variables...engine speed (rpm) and throttle position.
The lower the rpm, the less tolerant an engine is for open throttle.
You can cruise at 1000 rpm in sixth gear on flat land with hardly any throttle at all and you are not lugging the engine. Now, go to pass someone or climb a steep grade where you need to really open up the throttle and you are now lugging the engine.
4xlr8n is offline   Reply With Quote
Old 01-04-2017, 12:24 PM   #6
KMPrenger
KMPrenger's Avatar
I don't know about the M6, but I can tell you on the A8 (in manual mode), it will hold onto 8th gear when cruising on flat ground (steady throttle) until somewhere in 40 or even high 30 mph range. Seems like it won't force a shift down until 800-900 rpm.
I might not be remembering that correctly, but I do remember trying it out a while back and it surprised me how slow I could go before it would shift down.
Old 01-04-2017, 02:01 PM   #7
cbr1100xx
Drives: '14 Jetta 1.8, '19 1SS
I found 6th to be worthless unless I'm going 80+
cbr1100xx is offline   Reply With Quote
Old 01-04-2017, 02:35 PM   #8
F1FTY
Drives: 2018 ZL1
I use 6th as low as 46 mph depending on road conditions.
F1FTY is offline   Reply With Quote
Old 01-04-2017, 06:19 PM   #9
Quiksilver16ss
Yea I guess it depends on the situation y'all.. I figured 50-55 the bare minimum and if I need to accelerate I can go to 5th. Makes u wonder when the 1-4 shift kicks in if it's dangerous for the car or not. Less than 20mph in 4 gear and it sounds like it's lugging. Hmm GM
2016 Camaro 1SS
