Old 12-30-2016, 05:33 PM   #1
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Dealer figured out the rattle problem
A couple months ago I started getting a rattle in the passenger rear trunk area. Initially it was only when the top was up, then progressed to be continuous whenever I was on anything but the smooth roads.
Dealer thought it was the suspension, but figured out that it wasn't. They said it was from a latching mechanism that held the trunk piece in place.
I pick the car back up on Tuesday. I'll post the work order with the official diagnosis.
classicrockr is offline   Reply With Quote
Old 12-30-2016, 05:46 PM   #2
CyberGuyPR
CyberGuyPR's Avatar
Drives: '16 vert 2LT RS NPP
Interesting. I was trying to figure it out bu haven't used my card since it started snowing. I'm wondering if it involves changing something or just moving/rerouting/tightening stuff.
CyberGuyPR is offline   Reply With Quote
Old 12-30-2016, 08:03 PM   #3
classicrockr
They told me it was just a matter of lubricating & tightening something.
So far this has been the only issue. My 2012 had major top issues and I got $2700 & 60,000 extended top warranty from GM to keep from returning it under lemon law. And even with the extended warranty, I still had top issues. I traded up just before that warranty expired.
Old 12-31-2016, 04:28 PM   #4
Biggdummy
Biggdummy's Avatar
Drives: 2016 camaro 2ss vert
I have what sounds like the same rattle.I know its nothing serious,but it will drive me crazy if i don't find it.
Biggdummy is offline   Reply With Quote
Old 12-31-2016, 05:27 PM   #5
classicrockr
I will have an exact answer for you Tuesday!
Old 01-01-2017, 12:05 PM   #6
Biggdummy
Biggdummy's Avatar
Thanks !!!
Old 01-02-2017, 05:59 AM   #7
Mr_Finer_Things
Drives: 2016 SS Vert
So happy to hear this isn't on just mine and there's a fix.
Mr_Finer_Things is offline   Reply With Quote
Old 01-02-2017, 11:54 AM   #8
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
I have the same rattle
Hopefully the rattles are easy to fix... they're pretty annoying with the top up.
Also, I'm wondering if anyone else has an issue with either window hitting the convertible top when you open the door? My windows index on opening but not fast enough to stop the rub. To counteract this, I end up pulling the handle gently and holding the door so it doesn't open, wait for the glass to drop and clear the ragtop, pull the door open.
These issues aren't deal breakers, I'll be driving with the top down 90% of the time. Although, I'd love to hear about simple solutions...if there available. Thanks!
Old 01-02-2017, 06:32 PM   #9
mekirk2
mekirk2's Avatar
Drives: 2016 2SS Ragtop Garnet Red
mekirk2 is offline   Reply With Quote
Old 01-03-2017, 03:15 PM   #10
classicrockr
Well, the "latching mechanism" that holds the trunk deck in place is supposedly the problem. Mechanic said it is lubricated to keep it from vibrating on the bolt it's latched onto. He doesn't like the design of it.
After 4 miles, it started rattling again so I took it back. Service manager said he will now contact GM and they will basically walk him through possible solutions. He said GM HQ wont talk with him unless the car is in front of him.
Here we go again...
Old 01-03-2017, 03:29 PM   #11
CyberGuyPR
CyberGuyPR's Avatar
Oh boy! I got excited way too early. I took my car for a ride this weekend and heard the noise for 2-3 minutes out of the 1 hour trip. Very hard to pinpoint.
Old 01-03-2017, 05:52 PM   #12
LStick
Drives: 2021 Shadow Gray 1LS
Here we go again...
Had a rear door on a new Sierra extended cab rattling because of a bad machining job on the striker/latch mechanism.
Service advisor said there was nothing that could be done.
My ball peen hammer did the trick when I got back home from the dealer.
LStick is offline   Reply With Quote
Old 01-04-2017, 08:22 AM   #13
classicrockr
It IS hard to pinpoint. And once you're on smooth roads or going above about 45 mph, I can't hear it on mine anymore. Anything below 45 though & I hear it with EVERY little variation in the road's surface.
Old 01-04-2017, 08:28 AM   #14
diirk
diirk's Avatar
Drives: 2016 Camaro SS
Have them check the upper shock mounting bolts. It took a week and the service manager walking along side my car on the crappiest road we could find to narrow it down. Turned out the upper shock mounting bolts were not tight enough. They are accessed from the wheel well behind the liner. I think there's 2 or 3 bolts.
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad
91 Miata 1.8 Feal Wilwood Track Car
1morproject
diirk is offline   Reply With Quote
