Old 12-25-2016, 02:42 PM   #1
Sham001
PushRodLT1
Drives: M1SS1LE
Skip Shift Eliminator Install in NY or NJ
Greetings,
I am looking to have the Skip Shift Eliminator Which I bought from Amazon get Installed On my Car....I tried doing it myself with Jack Stands but just wasn't able to.....I called Several Transmission Shops here in NY within Long Island and NYC area and these shops have no Idea what I am talking about, does any body know any Transmission Shops in and around NY who has done this job on Other Camaros and can do this install for me?
Thanks....
2SS Black, M6, NPP, MRC
Mods: Borla ATAK Axleback w/NPP, Roto-Fab CAI, RPI Designs Splitter, ACS Spoiler, Michelin PS4S Tires.
Sham001 is offline   Reply With Quote
Old 12-25-2016, 02:57 PM   #2
mjmenke
mjmenke's Avatar
Drives: 2017 Camaro SS
I've done a 2002 Corvette and 2010 Camaro using a jack and jack stand. So it should be possible.
2017 2SS Black NPP A8 - 422 HP 427 TQ
mjmenke is offline   Reply With Quote
Old 12-25-2016, 09:32 PM   #3
Ss_outlaw
Drives: 2016 Camaro 2SS 6SPD
Don't worry I had to take my car in to get it installed too. Was very difficult to do with a jack and a stand
Ss_outlaw is offline   Reply With Quote
Old 12-26-2016, 07:28 AM   #4
JFM-jr
JFM-jr's Avatar
I sent you a PM
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 12-26-2016, 10:41 AM   #5
Sham001
PushRodLT1
Drives: M1SS1LE
Originally Posted by JFM-jr View Post
I sent you a PM
Thanks...
Old 12-29-2016, 08:36 PM   #6
crankaholic
crankaholic's Avatar
I did my CTS-V1 with a jack... the gen6 Camaro has the connector much higher up on the transmission and would be VERY difficult (if not impossible) to do without a lift :(
Any normal shop can do it though, it's just a simple connector.
crankaholic is offline   Reply With Quote
Old 12-30-2016, 11:20 AM   #7
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
I dunno... I did mine in my garage on jack stands up front & crawling under the car. Took me maybe 20 minutes total, a long flat blade screwdriver & a good shop light. And i'm 63, so not as nimble as I used to be. The hardest part was to get the top connector lined up correctly to push in. I used the long blade flat tip screw driver for that. Once lined up, it slid right in.
BrianL is offline   Reply With Quote
Old 12-30-2016, 12:19 PM   #8
crankaholic
Nice... I don't have a flat tip screw driver with a long enough blade, only have two jack stands (edit: looks like you do as well) and I couldn't get my hand in between the trans and trans tunnel. I guess anything is possible with the right tools and determination
Old 01-03-2017, 03:10 PM   #9
Ecchi667
Ecchi667's Avatar
Drives: 2016 Camaro 2SS, 6spd M
I used a 3.5 ton truck jack to lift the car, then used a creeper to slide under. Took a mildly frustrating 20 minutes or so, much the same as BrianL actually - I also used a flat head screw driver to push the plug in until it clicked.
At what point are you having trouble? Getting the OEM plug to release, or getting the eliminator plugged in? I found a decent light and a flat head screw driver were all I needed, but I'd say my hands are medium to large in size. If you have big hands, I can't imagine it'd be possible to get them up in there. Do you have any friends with small hands? Without the screw driver I don't think I'd have been able to get it myself (grab a cheap one from Walmart if you need to - it shouldn't cost you more than a dollar or two).
Ecchi667 is offline   Reply With Quote
