Old 12-22-2016, 07:30 PM   #1
inrandy
Randy
inrandy's Avatar
Drives: 2016 2SS Red Hot A8 Magride
rear tire wear
I had a rear tire patched because of picking up a screw. Discount tire showed me that I am down to 3/32 tread left on both rear tires, the front are at 7/32. I only have 1800 miles on my 2ss. I have never turned off the traction control and use sport mode mostly. I have owned a 2011 and a 2014 2ss and always got around 30000 miles out of the stock tires, I do not drive my 2016 any differently, I have a 21.5 average MPG. My dealers service manager said this is not normal and would look into maybe a problem with the car. Anyone else having extreme rear tire wear under reasonable driving conditions?
2016 2SS, A8, Magnetic Ride, Performance exhaust.
Randy
inrandy is offline   Reply With Quote
Old 12-22-2016, 07:49 PM   #2
MRRWheelsInc
Drives: Camaro
well my car is not a stang but one day it will be... but I did have a similar problem.. to the point that my front tires would outlast me 3 set of rear tires....... yes 3...
it wasn't until I finally went to a alignment shop and got everything squared away.
MRRWheelsInc is offline   Reply With Quote
Old 12-22-2016, 08:57 PM   #3
inrandy
Randy
inrandy's Avatar
What is a stang? Yes I see your point about driving tires not lasting as long as the front tires, but are you wearing out rear tires on a stock car with all traction controls in place in less than 2000 miles?
Randy
Old 12-22-2016, 10:14 PM   #4
Doyal_Mcneff
Drives: 2016 2ss
I bet the rears were toast from test drives before you bought it.
Doyal_Mcneff is offline   Reply With Quote
Old 12-22-2016, 10:22 PM   #5
diirk
diirk's Avatar
Drives: 2016 Camaro SS
Go to an alignment shop and get it checked out. If it's off, document it and bring it to the dealer. They should cover the cost of the alignment and replacement tires.
I drive very aggressively. Took the car to the drags. Numerous canyon runs. A half mile of burnouts, literally. I'm at 9k miles and can last another 1k at least.
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad
91 Miata 1.8 Feal Wilwood Track Car
1morproject
diirk is offline   Reply With Quote
Old 12-22-2016, 11:43 PM   #6
enzia35
Drives: '16 Garnet Red 1SS
Yes, please check alignment.
'16 Camaro 1SS
'18 Miata GT
Old 12-23-2016, 09:41 AM   #7
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
Must have bee the dealers "smokey burnout" test vehicle before you got it!
BrianL is offline   Reply With Quote
Old 12-23-2016, 02:35 PM   #8
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
I am at 14k miles and just checked this morning and have according to the service writer at GM 5k miles left? I was shocked. This is on the rears and they do not touch the wear bars yet but getting close. I drive fairly aggressive and even with traction control on whip the rear out on purpose several times but mostly hwy driving.
drivingagain is offline   Reply With Quote
Old 12-24-2016, 03:45 AM   #9
HyperSmurf
HyperSmurf's Avatar
Drives: 2020 Riverside Blue Camaro 2SS
I only got 12000 miles on mine, so I sent them off with an awesome Burnout.
https://youtu.be/e2xs6QdcM_E
I ended but mouthing the new BFG comp 2 A/S. so far they handle better and are noticing quieter.
2020 Riverside Blue 2SS
2016 Hyper Blue Camaro SS
2012 SIM Camaro 2SS
1971 Firebird Esprit w/ 455
HyperSmurf is offline   Reply With Quote
Old 12-26-2016, 11:49 AM   #10
franksredhot
franksredhot's Avatar
Drives: 2016 Red Hot Camaro 1SS A8
It doesn't sound right to have 3/32 tread at 1800 miles. Measure it yourself at the center because I think the edges come with only maybe 5/32 new. I just measured 6/32 at my rear with 5400 miles and 7/32 at front.
franksredhot is offline   Reply With Quote
Old 12-26-2016, 01:52 PM   #11
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
premature wear can be because the tires already were low like that when you purchased them, bad alignment, I doubt low tire pressure you'd know that off the bat.
PK Auto Design is offline   Reply With Quote
Old 12-26-2016, 05:46 PM   #12
diirk
diirk's Avatar
I think the main culprit for excessive wear would be incorrect toe
1morproject
Old 12-27-2016, 01:49 PM   #13
PK Auto Design
That normally is the reason.
Old 12-27-2016, 06:02 PM   #14
inrandy
Randy
inrandy's Avatar
Thanks for the info, My dealer is trying to get the ok from GM to replace the tires and check the alignment. Anyone with the magnetic ride control, How much smoother is your tour setting compared to the sport setting on not so smooth roads with grooves and raised areas? Even in tour mode I think my 2016 2SS is stiffer on rough roads than my 2014 2SS was with the original perallis on it. I wonder if the magnetic ride control could make the tires wear if not working right?
Thanks Randy
Randy
