Old 12-20-2016, 10:12 PM   #1
brado_4
Drives: 16' 2SS white npp mrc
Borla axleback or catback?
Hi guys looking to upgrade the exhaust i got npp ,should i get the axle back with the valves and then the mids or should i get the cat backs and delete the valves. Whats your thoughts. Also s type or attk. It so hard to buy an exhaust with only hearing it on the computer
brado_4 is offline   Reply With Quote
Old 12-20-2016, 10:46 PM   #2
somewhatdamaged
somewhatdamaged's Avatar
Drives: 16' 2SS M6
I prefer the ATAK, more aggressive. It's all dependent on what you want to spend, and if you plan to go long tubes. Check out my thread, I reviewed the axle back ATAK with no NPP valves: http://www.camaro6.com/forums/showthread.php?t=476988
If you get the secondary cat delete, besides the crushed pipe portion at the end, you really don't need the midpipe IMHO. Your SS already has a crossover, and I seriously doubt another xpipe will make much of a difference in power or sound, if any. Again, if money is no object, the valves and crossover are great quality products from Borla. Good luck!
somewhatdamaged is offline   Reply With Quote
Old 12-25-2016, 11:05 AM   #3
Akkoshi
Akkoshi's Avatar
Drives: 2016 Cameron 2ss
I went with the S type and the cat back pipes with the secondary cat delete. Sounds awesome. I also chose to keep the Npp it helps keep it quiet when you have a cold start early in the morning.
Akkoshi is offline   Reply With Quote
Old 12-26-2016, 01:54 PM   #4
camaromike77
camaromike77's Avatar
Drives: S O L D
Ditto here.........
Club F1FTY
Old 12-26-2016, 06:30 PM   #5
Epx998
|Engineer|
Epx998's Avatar
Drives: 2016 Camaro SS
Does cat back and the second cat delete make for an issue at the dealer?
Epx998 is offline   Reply With Quote
Old 12-26-2016, 08:55 PM   #6
Akkoshi
Akkoshi's Avatar
That all depends on the dealer. It's not monitored and the clamp is right before it so it looks like they might of entended for it to be deleted. I have not thrown a CEL with the secondary cat delete.
Old 12-26-2016, 10:36 PM   #7
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Same here. Absolutely perfect.
