Old 12-17-2016, 07:29 PM   #1
cbr1100xx
Drives: '14 Jetta 1.8, '19 1SS
Npp manual SS. Shifter vibrates?
Noticed this at idle and at some speeds too. Is this normal? Also this one did not do the skip shift to 4th. No matter how slow I shifted out of 1st. That was a welcome surprise though I'm confused why it didn't as it's a new car.
cbr1100xx is offline   Reply With Quote
Old 12-17-2016, 08:41 PM   #2
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I think a little vibration here or there is normal. Mine has an annoying buzz coming from the shifter area sometimes when pulling medium to hard above 4k rpm in second or third. It goes away if I put my hand firmly on the shifter. I cant find anything loose though.
As to skip shift - it engages from a dead start in first gear when the speed hits 15 mph and then disengages above 19 mph. So if you shift on either side of that range the skip shift does not engage.
476 rwhp/440 rwtq (sold)
Old 12-17-2016, 11:07 PM   #3
cbr1100xx
Ahhh good to know about the skip shift. My Camaro years and years ago engaged way more frequently...dunno the setting for it though. 2000 Z28.
Vibration was a little but no big deal. Other car did it too I tried that was new.
Old 12-19-2016, 11:40 AM   #4
Adp2017
Adp2017's Avatar
Drives: 2017 RS Turbo
I have the EXACT same problem.
Adp2017 is offline   Reply With Quote
Old 12-19-2016, 11:43 AM   #5
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
The shifter is suppose to vibrate and make some noise at times. It is directly linked to the drivetrain. These are nothing compared to an aftermarket shifter...with less isolation, they make more noise and transmit more vibrations.
Old 12-19-2016, 12:09 PM   #6
Mityguy
Drives: 2018 Hyperblue Camaro 1SS/1LE
I think its okay to vibrate a little. Mine does at least but so did my 5th gen. And now that I think about it my Cobalt did too lol..
Mityguy is offline   Reply With Quote
Old 12-19-2016, 12:47 PM   #7
cbr1100xx
Yeah vibration was minimal...no big deal.
So with regards to skip shift....so if you don't shift to 2nd between 15-19mph, no skip shift? That's pretty cool. Makes sense I guess I never was in that range b/c it never engaged. I tried to shift to 2nd at a crawl in the parking lot and it wouldn't engage. Makes sense now.
Old 12-19-2016, 02:01 PM   #8
SSDan
SSDan's Avatar
If you forget and try a shift between 15-19 rpm and you feel the shifter refusing to go to second - just go to third instead of fourth. It will take third and that's better than lugging the engine in 4th at such a low speed. On mine I see the dash message flash up just as I cross 15 mph and then it goes out as I roll past 20 mph. My normal driving pattern is to shift out of first after 20 mph and thus avoid the problem all together.
If you ever do some engine mods that require a tune the 1-4 skip shift feature can be turned off while you (or your tuner) are modifying the tune. That's what I did for my 5th gen Camaro. But I am not tuning this one so I just drive around it. You can also buy and install a skip shift eliminator plug in but the access for it on the tranny is really tight and hard to access. I'm not messing with that either.
