Old 12-17-2016, 02:28 AM   #1
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
I put the ZL1/ 1LE Sway Bars on my 2SS
I secured a set of the ZL1/1LE Sway Bars from ThatGMPartsGuy, I did the install today and will report back how different the car feels tomorrow. Unfortunately it was raining pretty good today to do any sort of real testing.
The install was simple, but I quickly realized the set I got was for non-MRC equipped cars, so I didn't need the Links as my car already had them.
I am putting together the install guide and a quick review of how these bars change theverything feeling of the car in situations that actually make use of the Sway bars.
Sledgehammer70 is offline   Reply With Quote
Old 12-17-2016, 07:37 AM   #2
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
Sweet, looking forward to your findings and video
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 12-17-2016, 07:55 AM   #3
BowtieRocket
BTW those aren't end links in the kit, they're front lower control arms...
Old 12-17-2016, 09:18 AM   #4
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
So MRC cars already have the same LCA as the 1LE?
EDIT: I was looking at another thread and it sounds like it's the bushing material on the LCA that is different in the parts included in the kit. Are you sure they are the same as what you had in your car? They may just look the same.
Eric SS is offline   Reply With Quote
Old 12-17-2016, 09:53 AM   #5
BowtieRocket
My guess is the bushing/bearings are upgraded in this kit and is the same actual LCA. Just like how BMR offers upgraded front end LCA and Radius rod bushing/bearing kits...
Old 12-17-2016, 10:12 AM   #6
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
Can you please report the sway bar diameters SS/1LE?
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 12-17-2016, 10:42 AM   #7
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Plus the wall thicknesses for any bar that is not solid.
Be best with the two front bars pictured together and the two rear bars pictured together. Overall shapes and in particular the 'arm' lengths matter.
Norm
Old 12-17-2016, 11:09 AM   #8
Mountain
Mountain's Avatar
SS 1LE / ZL1, non-MRC...?
And the other comments are right, the lower link has a spherical joint rather a bushing.
Old 12-17-2016, 02:02 PM   #9
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
why oem instead of afe power or eibach or bmr?
Old 12-17-2016, 04:04 PM   #10
BowtieRocket
Bet the 1LE trailing arms and control arms are still spaghetti...
Old 12-17-2016, 11:57 PM   #11
Sledgehammer70
Lethal Camaro
GM calls them Links in the guide and via part number. So I went with what they called them.
Old 12-17-2016, 11:58 PM   #12
Sledgehammer70
Lethal Camaro
Neither of those companies have tested their components on anything other than a SS with 455hp.
Old 12-18-2016, 05:54 AM   #13
rorymick
rorymick's Avatar
Drives: 2016 Camaro RS 1LT 2.0L Turbo
How's the car with the new parts? Very noticeable improvement?
'16 1LT 2.0T RS - Catless DP, Intake, Tune/ Eibach springs FE3 shocks/ BMR front bar FE4 rear bar/ Xpel'd front end, CP Reload sealed/ Radenso Pro M.
rorymick is offline   Reply With Quote
Old 12-18-2016, 06:42 AM   #14
Norm Peterson
They are in fact more properly called 'links', most likely because they have exactly two pivots, one at each end. This probably sounds picky when most DIY'ers call just about every suspension arm or link an arm, but it's technically correct to call these things links.
They just aren't "endlinks".
Norm
