Old 12-13-2016, 06:21 PM   #1
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
Different Tire Sizes
I think the Supercar tires on our 1LE's will be really good, but if you go with something else on stock wheels like Bridgestone RE71R, they only come in different diameter 285/35/20 or 295/30/20.
Just wondering how much that will mess up the traction control, PTM ,etc.
JRL1LE is offline   Reply With Quote
Old 12-13-2016, 08:08 PM   #2
Master357
Master357's Avatar
Drives: 2017 1LE
Wheels:.............Wheel 1............... Wheel 2
Wheel size.........20x11 ET 20..........20x11 ET 20
BackSpace ........172 mm................172 mm
Weight..............~ 45 lbs ................~ 45 lbs
Tire size............305/30-20..............295/30-20
Section width.....305 mm (12'')........295 mm (11.6'')
Sidewall............92 mm (3.6'').........89 mm (3.5'')
Tire diameter.....692 mm (27.2'')......686 mm (27'')
6 mm (0.9%) shorter.
Circumference....2173 mm..............2154 mm (84.8'')
Revs per mile.....740......................747.1
not a huge difference. I don't know how sensitive the PTM is.....
Master357 is offline   Reply With Quote
Old 12-13-2016, 08:46 PM   #3
TJay74
If it is anything like the staggered setup on the C6 and newer Corvettes, as long as you stayed with in 1" or less of the difference in tire heights you were fine. The ABS and TC worked just fine.
When I replaced the tires on my corvette I went wider on the front and rear and had zero issues at all.
Old 12-13-2016, 10:11 PM   #4
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
So if I run 285/35/20 square, which is 27.9 diameter or 295/30/20 which is 27.0 diameter should be fine?
Old 12-13-2016, 11:07 PM   #5
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
Originally Posted by Master357 View Post
Wheels: Wheel 1 Wheel 2
Wheel size 20x11 ET 20 20x11 ET 20
BackSpace 172 mm 172 mm
Weight ~ 45 lbs ~ 45 lbs
Tire size 305/30-20 295/30-20
Section width 305 mm (12'') 295 mm (11.6'')
Sidewall 92 mm (3.6'') 89 mm (3.5'')
Tire diameter 692 mm (27.2'') 686 mm (27'')
Circumference 2173 mm 2154 mm (84.8'')
Revs per mile 740.6 747.1
Great info, thanks
Old 12-13-2016, 11:30 PM   #6
Master357
Master357's Avatar
Drives: 2017 1LE
Originally Posted by JRL1LE View Post
Great info, thanks
No problem. I fixed it so it is readable now.
Old 12-14-2016, 12:13 PM   #7
FLO-RS
Drives: 2010 Honda Fit Sport 5MT
Hi folks, long time lurker here. Noticed that you were looking into different tire sizes at about the same time I was, and decided to create an account just so I could link you this nifty tool I found awhile back. Here you go:
http://www.miata.net/garage/tirecalc.html
By the way, for anyone else who is interested, the overall diameter of the stock 18" tires is almost exactly the same as the stock 20" ones.
FLO-RS is offline   Reply With Quote
Old 12-14-2016, 05:05 PM   #8
TJay74
GM uses the same over all height for most of the tires in a model. On the trucks for the 17", 18", 20" and 22" wheel options they all use the same tire height in the computer. This saves GM from having to write a different calibration for every wheel/tire option they offer with in a vehicle line.
