Old 12-12-2016, 12:19 PM   #1
LS6-M22
Rockcrusher
Drives: 2017 SS 1LE
1LE eLSD pics
I put my car on the lift today and was checking out the eLSD. Seems pretty robust!. I'm not sure if the regular SS has a iron center section but the 1LEs do.
LS6-M22 is offline   Reply With Quote
Old 12-12-2016, 01:03 PM   #2
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Yup it is beefy as it has to hold up to the Z06 and ZL1 with their added torque...
I see the SS 1LE has a different part number for the right side axle, I hear it is a little shorter than the regular SS due to the eLSD. Hard to see in your pics, but does it look any thicker then a regular SS right side axle to you?
Old 12-12-2016, 01:06 PM   #3
bub
Drives: '17 1SS 1LE & '15 Corvette Z06
I don't recall seeing the iron section on my Z06 transaxle diff.. Will need to look again.
Good info. Thanks for posting pics.
bub is offline   Reply With Quote
Old 12-12-2016, 01:08 PM   #4
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Possible that may slightly differ due to the rear mounted transmission. I did compare the SS 1LE and ZL1 part numbers for the whole center section, they are the exact same.
Old 12-12-2016, 01:08 PM   #5
LS6-M22
Rockcrusher
Drives: 2017 SS 1LE
I have never seen a regular SS axle so I cant compare the two.
Old 12-12-2016, 01:10 PM   #6
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Valid point. Maybe someone can post a pic of a regular SS right side axle to compare, I can't find a good picture.
The SS 1LE right side axle being shorter alone is a good thing...shorter axle = stronger axle.
Old 12-12-2016, 02:04 PM   #7
COmaro
Drives: Many
Is the 1LE driveshaft steel or aluminum?
COmaro is offline   Reply With Quote
Old 12-12-2016, 02:36 PM   #8
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Great picture!! Thanks!
Old 12-12-2016, 06:33 PM   #9
HyperBlue
HyperBlue's Avatar
Drives: 2011 MB E350 wagon
That's good stuff! Thanks for posting.
2015 BMW M235i (sold!)
Old 12-12-2016, 07:15 PM   #10
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Regular SS diff: http://www.koonschevybuickgmc.com/ne...846b887964.htm
Old 12-12-2016, 08:52 PM   #11
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Originally Posted by vtirocz View Post
That's just a car for sale listing no lol?
Old 12-12-2016, 08:53 PM   #12
glenB
Drives: Chevrolet Camaro SS
Tale of the tape
Top is the SS bottom is the 1LE
The 1LE looks beefier
glenB is offline   Reply With Quote
Old 12-12-2016, 08:58 PM   #13
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Originally Posted by glenB View Post
Tale of the tape
It sure does...plus all the noise issues the regular SS diffs are having shouldn't be an issue with these.
Old 12-12-2016, 09:00 PM   #14
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
...now all we need is a right side axle comparison.
Curious if when they made it shorter if they made it any larger diameter too.
