Drives: 2016 2SS Camaro Join Date: Sep 2016
Sway bar end link failure (lowered)
Right front end link broke while leaving the parking lot at the shop. There is kind of a sharp transition there and I leave at an angle. Heard it pop. Pulled the wheel and there's no fixing it. The end links are a sealed "ball and cup" style with a stud sticking out that mounts on each end.
I did lower the car last week with BMR springs. Might have made a difference? I'm guessing cheap design on these end links. I should have taken a shot of the other end for comparison. What is missing in this photo is the ball ended stud. The nylon bushing inside this boot failed and the ball popped out of the socket. |
![]() ![]() ![]() Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
I had a pair of billet endlinks from BMR on my mustang and they were BEEFY. If you didnt get the torque spec 100% correct they clunked. Time for an upgrade! I doubt they will warranty it now that you have voided the suspension warranty. Shouldnt be too costly though.
Not even gonna go to the dealer. I'll just buy one and replace it.
![]() Drives: 2016 SS, BLACK, MANUAL Join Date: Apr 2010
When I was installing the front Eibach lowering springs, I found the left sway bar link with the "grease" coming out of the top stud bolt, this due to the retaining spring not holding the rubber seal closed. I installed a new link.
2016 Black/Black SS, 6speed, MRC, Roto-Fab air intake, Vitesse controller,
1 7/8" headers and exhaust from Stainless Works complete with nonNPP mufflers and 5"outlets, Katech ported TB, Moroso catch can, MRR M017 polished powder wheels, Eibach lowering springs, and BMR upper/ lower trailing arms and upper control arms. ZL1/1le sway bars and Magnusson Supercharger with Jannetty tune. Stay Tuned!!!......More to come. 2014 Camaro Ashen grey, 3.6, 6 speed, Vararam intake, Elite catch can, chrome wheels, and Vitesse controller. 2003 SSR red, 2016 Vette |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
lol time to upgrade!
I'll replace it for now. Upgrade if it breaks again.
#7 |
![]() Drives: 2016 1SS Camaro Join Date: May 2016
I got a pair I'll sell pretty cheap. I removed my sway bar, so they are just sitting around. Around 200 miles on them.
#8 |
I'll let you know. Pretty sure they only run about $30 each
#9 |
SABIO
Spend the 100 and get BMR links. Done.
#10 |
im waiting on powergrid to make them ill probably be the test car lol
#11 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
I would upgrade to adjustables, honestly. Since you're lowered, you're going to want to get the sway bar pre-load correct and the kinematics (geometry) of the sway bar system corrected. Im assuming these two points are off now...
#12 |
Yeah went ahead and ordered the BMRs
