Old 12-07-2016, 01:08 PM   #1
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
GM PERFORMANCE HEADS/CAM
anybody seen this yet?
PRODUCT DESCRIPTION
LT1 Head Kit
Increase your already-strong LT1 with these CNC Ported Heads and camshaft designed specifically for direct injection. This is the first "Hot Cam" for the Gen V LT1.
Specs:
Duration @ .050 Lift(deg) - I:.577 / E:.577
Maximum Lift (in) W/ 1.7 rocker - I:228 / E:248
Lobe Separation (deg) - 116.5
NOTE:
Installation of this kit will affect engine variable valve timing and active fuel management operation. Re-calibration is required for accurate engine operation (Not available from GM, must be tuned by an aftermarket source)
http://www.thatgmpartsguy.com/perfor...25?parent=1023
Old 12-07-2016, 01:12 PM   #2
AbsolutHank
AbsolutHank's Avatar
Drives: 2016 Corvette Z06 M6
http://www.camaro6.com/forums/showthread.php?t=439558
2013 Dodge Viper #44/150 Launch Edition IG:@absoluthank
20/21 BC Forged Wheels : BC Coilovers: TA Aero
AbsolutHank is offline   Reply With Quote
Old 12-07-2016, 01:14 PM   #3
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
I've seen it. I've also been waiting to see someone install it so that we can get real world numbers. I haven't looked at cam specs since I had my LS1, so I'm not sure how it will behave. I assume the idle gets slightly more aggressive.
Seems expensive, but again, the last time I was in the mod game was in my F-Body, where parts were plentiful and costs were down.
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
Old 12-07-2016, 01:16 PM   #4
2K16SummitSS
Originally Posted by AbsolutHank View Post
Missed this one, I'll have to read through.
Old 12-07-2016, 02:28 PM   #5
Mityguy
Drives: 2018 Hyperblue Camaro 1SS/1LE
I've not seen it yet. This is the Cam I went with
https://www.summitracing.com/parts/CCA-624-500-13
Mityguy is offline   Reply With Quote
Old 12-07-2016, 02:38 PM   #6
kropscamaro16
haha whoops totally missed it sorry
Old 12-07-2016, 03:40 PM   #7
RonAndersonJr
RonAndersonJr's Avatar
Drives: 2016 Camaro 2SS Black on Black
If we have to get a tune from a third party, which will ruin the warranty, why not just get a cam from a third party anyway?
RonAndersonJr is offline   Reply With Quote
Old 12-07-2016, 03:49 PM   #8
ender2664
Drives: 2016 2SS
Costs too much and voids your warantee, might as well go aftermarket.
ender2664 is offline   Reply With Quote
Old 12-07-2016, 04:40 PM   #9
slick3
Drives: Garnet Red - 20 ZLE
90% of that power is rated from the cam. better off getting a custom grind that fits your driving style. Krops, have CMS spec you a cam. I think they charge like 4200 for a cam, install and tune.
slick3 is offline   Reply With Quote
Old 12-07-2016, 05:23 PM   #10
oldman
Drives: SS 6 speed of course
IMO, the GM cam is a true 100,000 mile street cam. Sorry I've been through the broke LS1 valvetrain days that went on for YEARS. I like cams under .600 lift and gentle ramps cause I don't want to take it apart for 100,000 miles. I must have changed 100 broken whatevers on LS1 when the cams lift started to go big or go home... most time it was go home on the back of a flat bed. Yep, I'm old and probably wrong. But I ain't doing it again.
Old 12-07-2016, 05:41 PM   #11
slick3
You make a valid point. Correct me if I am wrong but hasnt the valve spring technology also came along way from 15 years ago?
Old 12-07-2016, 06:57 PM   #12
kropscamaro16
haha alraedy got a quote from them and yup that price is spot on and also included a E85 tune should be making around 500hp with all that and what i alraedy have
Old 12-07-2016, 08:15 PM   #13
oldman
yep that's what they said 15 years ago too. Like I said it went on for years and every new and better widget would fail in time and I'm not talking 80,000 miles here. My Honda can go to 10,000 RPM with no valve float, so it ain't like I don't know anything about valve train.
Old 12-07-2016, 08:21 PM   #14
slick3
Are you saying I shouldn't believe everything I read on the internet ?
