Old 12-05-2016, 09:05 PM   #1
TimmyTurner
Drives: Matte Black 2016 Camaro SS
Grinding or rubbing sound when vehicle is cold
I constantly hear a rubbing or grinding sound when turning from the rear of my car only when the car is cold. Cold as in haven't driven it for several hours.
The rubbing grinding happens in hot weather and cold weather.
Anyone else have this issue or know what it is?
TimmyTurner is offline   Reply With Quote
Old 12-05-2016, 09:15 PM   #2
goshawk823
goshawk823's Avatar
Drives: 2017 RS convertible
Check here:
http://www.camaro6.com/forums/showthread.php?t=440272
Camaros I've owned:
1969 RS/SS Z10 Indy Pace Car - Hardtop 1 of 250
1970 Camaro
2010 2LT RS
2013 2SS RS
Current ride:
2017 Camaro 2LT RS convertible
goshawk823 is offline   Reply With Quote
Old 12-05-2016, 09:25 PM   #3
OddJack
OddJack's Avatar
Drives: Submarine
is this V8 only or V6 too?
OddJack is offline   Reply With Quote
Old 12-05-2016, 09:31 PM   #4
Rickster1001
Rickster1001's Avatar
Drives: 16 Camaro 2SS
Diff. Fluid
Rickster1001 is offline   Reply With Quote
Old 12-06-2016, 07:48 AM   #5
Raven87
C'mon- really?
Raven87's Avatar
Drives: Looking for a ZL1
Originally Posted by CreativeDawn View Post
I got my car back after a service today (Dealership) and they said in a memo that everything is normal and nothing is wrong with the car. I still mentioned the noises heard from the back but they said it's normal.
A noisy diff is NOT normal. Keep pressing them about it or go to a different/better dealer because they are BS'ing you.
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD
Raven87 is offline   Reply With Quote
Old 12-06-2016, 07:53 AM   #6
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Yep!
also there are a lot of threads regarding this. Its happening to vettes as well.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 12-06-2016, 08:14 AM   #7
Raven87
C'mon- really?
Raven87's Avatar
Originally Posted by oneredry View Post
Yep!
Definitely. I have had the same problem in just about every GM vehicle I've bought over the last several years. It has to do with the fluid they put in for the new build and the break in process. There is an anti-friction additive that needs replaced at about 500 miles or so sometimes sooner.
Like I said, this is not anything new but a dealer that tries to say it is 'Normal' is not worth his franchise.
Steve
Old 12-06-2016, 08:16 AM   #8
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
This is a known issue and is not normal. Let your dealer know that this is happening on a lot of Camaros and that a diff fluid change is required. Have them call GM if necessary. I would probably choose a different dealer as well.
Eric SS is offline   Reply With Quote
Old 12-06-2016, 08:18 AM   #9
Raven87
C'mon- really?
Raven87's Avatar
From the manual:
Usage Fluid/Lubricant
Rear Axle (L4 and V6 Engine with Automatic Transmission)
Dexron non-LSD Gear Oil (GM Part No. 88863089, in Canada 88863090).
Rear Axle (L4 and V6 Engine with Manual Transmission)
Rear Differential Fluid 75W-90 Limited Slip (GM Part No. 88900401 and
Limited Slip Additive 88900330, in Canada 89021678 and Limited Slip
Additive 00992694).
Rear Axle (V8 Engine)
Rear Differential Fluid 75W-90 Limited Slip (GM Part No. 88900401, in
Canada 89021678).
Add Limited Slip Additive GM Part No. 88900330, in Canada 00992694
Steve
Old 12-06-2016, 08:31 AM   #10
oneredry
HYPER SS
oneredry's Avatar
From the manual:
Additive 00992694).
Canada 89021678).
actually the limited slip part has changed since then. I did a thread on me talking directly with GM in regards to this. the correct fluid is actually 88862624 which is combining of the limited slip and the original fluid..
Please reference to thread>
http://www.camaro6.com/forums/showthread.php?t=459727
Ordered: 1/15/2016
Delivered 03/23/16
Old 12-06-2016, 08:38 AM   #11
Raven87
C'mon- really?
Raven87's Avatar
Thanks for the insight - my info was taken from the online 2016 Camaro Owner's Manual.
Steve
Old 12-06-2016, 09:13 AM   #12
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
nor·mal
ˈnôrməl/
adjective
adjective: normal
  1. 1.
    conforming to a standard; usual, typical, or expected.
Being that this seems to be happening to the majority, by definition, doesn't that make the dealers correct when they say its "normal"?
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
Old 12-06-2016, 09:26 AM   #13
Goobaba
Drives: 2016 V6 RS Manual
Happens in my car as well, brought it to the dealer, of course by then the car was warm and noise gone. Left it over night, they said they couldnt hear it (bullsh*t) cold the next morning. On my to do list to bring it to another dealer when I get some time.
Goobaba is offline   Reply With Quote
Old 12-06-2016, 03:10 PM   #14
nearwater
nearwater's Avatar
Drives: '17 2SS 50th
I actually didn't change mine yet, and I'm at 6000 miles.
Is it recommended to change around 1500?
Mine doesn't make any sound so far. (Knock on wood)
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
nearwater is offline   Reply With Quote
