Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
Questions on Trailering my new ZL1
Does anyone on the list trailer their cars to road tracks?
What type trailer do you use? What type truck to you haul it with? [The Trailer] I'm looking at getting a white 2017 Diamond Cargo 8.5x24 TA 5200 from a nearby dealer. I told them what I'd be using it for and the owner said their 8.5x24 trailer could handle it. I did some web searching for specs but I'm not sure if this will safely haul my ZL1 to and from the track. To be honest, it's a little confusing how they rate the models. I'm sure they're rated based on the suspension / springs but I don't want to buy it and find out later it's unstable. Specs Photo of a silver one From the spec charts it looks like the max gross weight (6800 lbs) is under the combined trailer+ZL1 weight. trailer weight (3600 lbs) + ZL1 curb weight (3880 lbs) = 7400 [The Truck] I have and old 1990 C1500 extended cab, long bed pickup with a towing package. Bought it new in 1990 but it's seen better days in its 500,000+ mile life so far. It originally came with a 4.3 L V6 but I'm having a 4.7 L (small block 350) V8 put in it. the heaviest thing I've hauled with the V6 was a full cord of firewood, half in the bed and half on a 8 ft utility trailer. It was very stable in this configuration. I didn't drive it very fast, though. What about brakes? I'm pretty sure the trailer doesn't have its own brakes. The guy that's putting in the motor for me says that a brake pad upgrade and rotor shave should handle it. Thanks for any insights you guys can offer. --Cal |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
The trailer in the pic should work just fine as long as there are good tiedowns in the floor and remember you will have to climb out the window once the car is in the traler. The truck to pull that traler should be a 3/4 ton atleast. That's a lot of weight for a 1/2 ton.
#3 | |
![]() Drives: 2020 ZL1 Join Date: May 2010
I trailered my 2010 Camaro to the track for a few years on a Featherlite open trailer that I pulled with a 2004 3/4 ton Suburban. Probably 1000 pounds less than what you are planning to pull. Pulled great, I could set the cruise at 75 and it hardly ever downshifted. That truck had the 8.1L and the 4 speed auto.
Trailers have brakes, you'll need an electronic brake controller added to your truck. The trailer dealer should be able to help you with this. Your closed trailer, car, and things that you take to the track is going to weigh 8000 pounds. You'll probably get tempted to add cabinets, extra tools, a tire rack for spare wheels and tires, etc..... Would I want to pull that with a 25 year old 1/2 ton pickup? Nope. And it's probably over the tow rating of that truck. Moving the load isn't the problem, stopping the truck and trailer is the problem. I live in Syracuse, NY and went to Watkins Glenn, Pocono, NJMP, VIR, Summit Point, Lime Rock, etc.... Then I got sick of loading and unloading the trailer, so I went back to just driving the car to the track, driving at 8/10th's, and having a nice day. Only time it didn't work out was this summer when I blew a motor, but I got a ride home with my father who was at the track day with me, and had the car picked up by AAA. Quote:
2020 ZL1
#4 | |
Drives: Callaway Corvette Join Date: Oct 2009
For the trailer, it looks like they have electric brakes on each axle, as with other trailers would/should. If not, be sure to up your life insurance, as you WILL need it. Think you meant 5.7L for the new engine, which is fine, if there's enough gearing. Which may not be the case, given it was a 6 cyl, originally. And then there is cooling for engine and trans. I could go on and on. Been pulling a trailer for 15 years - open, enclosed, w/ trucks and SUVs. Best one by far was enclosed, pulled by the diesel Excursion |
#5 | |
Cal
I was hoping I could get it done with a few upgrades to my 1/2 ton but the more I'm reading, the more I hear that 3/4 ton is best. Is the biggest factor the load on the axle and drive shaft? Springs only come into play for loads in the bed and tongue weight. I may have to sell my 1990 C1500 and my 2005 Colorado to upgrade to a good, used 3/4 ton. |
1959 Chevy Apache 4X4
Drives: 2017 ZL1 Join Date: Feb 2016
I was towing a big wake boat with a Dodge 1/2 ton hemi. I averaged 9 mpg. I then upgraded to a 2007 Ford F250 and averaged 15 while towing. It handled hills and mountains wonderfully.
If I buy again, I will look into a 1 ton. My buddy just bought a new 3500 non-dually chevy for cheaper than a similarly loaded new 2500. It's very nice :-) but I now currently pull a boat with a 1959 Chevy Apache 4x4 with a modified 383 stroker and a 700r4..........it's more fun just food for thought |
#7 |
![]() ![]() Drives: SW 2017 ZL1, M6, Carbon, Nav, MR, Join Date: Dec 2012
Inside this 4600 lb trailer is a 5000 lb pick up truck. I have a GMC Sierra 1500 and it pulls it just fine with an 11,200 lb towing capacity and even switches to 4 cylinders when cruising on the highway. Absolutely unbelievable. It is an 8.5 X 20 anto hauler. Save yourself some money if possible by considering the shorter trailer.
I am pulling this from Texas to Cali in a few weeks. A Camaro will fit just fine, but I have no idea how you get out. Climbing out the window isn't an option for me. |
#8 | |||
Cal
What do you think in terms of trailer length. I was originally looking at a 8.5' x 24' but at 15.8 ft, the ZL1 would fit in a 20ft model too. Just worried about room for the extra stuff later, like tool box, compressor, generator, and tires. As for weight, I should be okay with any tandem 5200 axle model. For tandem axle trailers, that's 5,200 lbs per axl or 10,400 lbs max gross vehicle weight. Looks like the 20-24 ft models weigh 6200-6600 lbs. So I guess I'll be okay with car, trailer, tools, compressor, generator, spare tires; as far as what the trailer can carry. Quote:
Thanks for the feedback! --Cal |
#9 |
^Name^ | Things I Say -->
Drives: 2016 2SS Convertible, Hyper Blue Join Date: Oct 2016
Why not save a bunch of money and weight and go with an open trailer? Just food for thought.
#10 | |
Cal
Looks like I've got some more homework to do before deciding the upgrade the C1500 or sell/trade for a 3/4 ton. I'm retired Marine so I can use the auto shop on the nearby base to do any big work. I just don't have a ton of time these days with my work keeping me busy. If it's a 1 or 2 day job I can handle it. Anything longer and I'd have to hire someone to do it. --Cal |
#11 | |
Cal
Since I'm locked into the engine upgrade on my C1500, I'll decide about the trailer first, get the wiring done with brake controller, then test it out locally; first empty, then with my Colorado inside. If it doesn't feel safe I'll breakdown and sell my two trucks and get a good used 3/4 ton. That's gonna be hard because I bought this C1500 new and only recently stopped using it when the nearby Chevy Dealership's service dept killed the motor. --Cal |
#12 | |
Cal
--Cal |
#13 | |
Cal
The gas mileage and wear-n-tear on a smaller truck is definitely a consideration. Thanks. --Cal |
#14 | |
