Old 12-04-2016, 05:19 PM   #1
Gauges and/or Gauage Pod... who's got them?
Has anyone installed gauges? Is there an A-pillar POD available?
Let's see some pics of what you have installed.
Old 12-04-2016, 05:50 PM   #2
turbojeep95
turbojeep95's Avatar
Drives: 17 Camaro lt, 22 Camaro LT1
I'd love to see what some members come up with. I need a clean way to mount a boost gauge.
turbojeep95 is offline   Reply With Quote
Old 12-04-2016, 10:06 PM   #3
Why a boost gauge?
Old 12-05-2016, 09:14 AM   #4
turbojeep95
I have a 17 1LT turbo. Here it doesn't come with a factory boost gauge. I'm either going to go with a aftermarket gauge or keep hoping for something in the AppShop.
Old 12-05-2016, 10:22 AM   #5
If it was a 5th Gen the ZL1 gauge cluster would probably work.
Old 12-09-2016, 09:52 PM   #6
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I just use DashCommand on my phone since it actually logs the data from the gauges.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 12-09-2016, 09:58 PM   #7
That's a good way to go but I already have HP Tuners for logging and all parameters. Just want something on my A-pillar primarily for IAT2 and Wideband O2.
Old 12-09-2016, 10:07 PM   #8
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Oh I gotcha...yeah there actually are a few things that you need to add sensors for that won't through the OBDII port.
Old 12-09-2016, 10:29 PM   #9
Even if I have to use the OBD port that's fine for normal day to day driving. Then swap over to laptop for the track. But leaving it open would be best.
I guess it will be a while before aftermarket catches up and makes the A-pilar POD.
Old 12-13-2016, 08:17 AM   #10
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Yeah and actually some stuff is fine coming from that port and going into an app, but other things aren't. Sometimes you get some spikes or anomalies, so everything can't really be trusted if you need to make decisions off the data. I use it more for fun or to see changes (compare before and after).
I was off from work yesterday and popped over to Jannetty's and asked about this. I'm pretty sure that there are gauges and sensors out there we can use. They'd need to be wired in. He didn't think we'd ever see something like a "gen6 Camaro gauge package", but we should be able to use gauges that are already available as long as they can pull data from a sensor. Unfortunately I don't know enough about this to point anyone in the right direction other than asking your local speed shop for a recommendation.
Old 12-13-2016, 08:29 AM   #11
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
I just received the 2-gauge pod from Aeroforce to house my Aeroforce and AEM CAN wideband. It mounts in place of the left defroster vent and up alongside the OEM gauge cluster. The housing is a semi-crude resin molded piece and fully functional as is, but I think I'll take the time to do some light finish sanding then prime and paint it for a better look. I guess we can't expect a true injection molded part in the volume this piece sells in.
I also ordered the relay output module so I can run an additional fan on the HE with the IAT2 as a trigger.
Will post pics when I get my car back and everything installed.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 12-13-2016, 08:34 AM   #12
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Oh nice...can't wait to see that!
Old 12-13-2016, 10:57 AM   #13
diirk
diirk's Avatar
Drives: 2016 Camaro SS
It'd be nice of there was a P3 guage available for the Gen 6.
Make the request and if they get enough interest, maybe they'll make one.
If you're not familiar with the P3. It uses an OBD2 reader and has the capability to support analog sensors too. It mounts in the stock air vent.
Here's the Gen5 one.
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad
91 Miata 1.8 Feal Wilwood Track Car
1morproject
diirk is offline   Reply With Quote
Old 12-19-2016, 09:04 PM   #14
Block8head
Block8head's Avatar
Drives: 2016 Vert 2SS/2018 ZL1 Vert Red Hot
I mounted mine here. Single vent pod.
Block8head is offline   Reply With Quote
