Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
First Mod: Front Rock Guards Installed
Just finished installing ZL1 Addons front rock guards for the 6th gen Camaro on my ZL1.
The guards are a made of very high quality plastic. Fit and finish is excellent. Install was very easy. My only knock is you can see the 3M VHB tape at certain viewing angles. They're definitely going to block a lot of rocks thrown up by the front tires.
those should definitely help. interesting I had their 5th gen guards on my '14 and those were held in place with Z-clips that were mostly hidden. looks like now its 3M tape.
'17 ZO6 - Watkins Gray Metallic
'17 911 4GTS - Carmine Red '17 Bolt - Hyper Blue '02 SS - 35th Anniversary Ed. - 645 miles '89 IROC Z - 2500 miles '73 Z28 - Survivor 36k miles '69 RS/SS 496 - 631 HP 618 TQ '67 SS - Alum. 406 under construction |
#3 | |
![]() Drives: '15 Summit White ZL1 Join Date: Oct 2014
Drives:
2017 ZL1 - Hyper Blue Metallic Drove: 2015 ZL1 - Summit White 2006 GTO - Phantom Black |
#4 | |
![]() ![]() ![]() ![]() Drives: 2017 ZL1 10 Speed Hyper Blue Join Date: Jul 2016
2017 ZL1
![]() ![]() ![]() ![]() Drives: 4 wheels Join Date: Dec 2009
looks great and simple.
Coupe Newbie
The Showstopper rock guards I had on my '13 ZL1 also used Z-clips. The tape and z-clips both have trade-offs. The clips dig into the paint and can eventually cause the area to rust. The tape is visible from certain angles. In the long run I think I'll prefer the downside of the tape.
#7 |
White knuckled & smiling
Drives: '17 ZL1 AKA Perfection! Join Date: Aug 2015
Black sharpie for the win.
#8 |
![]() Drives: 89 Turbo Trans Am Join Date: Oct 2016
They look good, factory should do this anyway. Will tape hold those at 150+mph though?
#9 |
Retired from Car mfrs....
Get a small artist paint brush, and some rust oleum flat black paint, and paint the edge of the tape if it bothers you. I've done it on a few cars
#10 | |
Drives:
#11 |
2017 ZL1
#12 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
Didn't need them on the 5th gen, clear bra works great!
#13 |
![]() ![]() Drives: 2017 ZL1 Join Date: Oct 2016
You can buy black, white or gray 3m vhb tape.
That stuff will definitely hold, that stuff is amazing. |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 GT350 Join Date: Nov 2011
I used the 5th gen ZL1 front mud guards on my 5th gen SS when I changed wheels, and I also preferred the tape since the clips would just rip into the plastic and remove paint.
I'm not sure if the 6th gen has as much room as the 5th gen, but I was able to take the 3M, cut it in half, then run it tightly along the fender liner and entirely hid it. And it will hold during spirited driving in my experience. That first time you hear a rock SMACK off that plastic, and know it didn't hit your fender, it justifies its entire purchase.
Off to the Dark Side
