Old 11-29-2016, 11:29 AM   #1
Notorious
No Hope
Notorious's Avatar
Thumbs up Hellion Power Systems - Turbo Kit
I have been speaking with Jeff Yochim from Hellion Power Systems who tells me Hellion will be releasing a turbo kit for the 6 Gen Camaro.
He did not provide much details as to if it will be single or twin turbo but he did say and i quote..
"this will be the most powerful kit available"
Coming Spring 2017!
http://www.hellionpowersystems.com
2016 Camaro 2SS - M6 | Hyper Blue Metallic | NPP | MRC | Sunroof | Navigation | Black Bow Ties | ACS Spoiler | Black Tail lights | ZL1 1LE 3rd Brake Light | Roto Fab CAI | Stainless Works Cat-Back | Black 1LE Wheels | Nitto NT555 G2's 285 Front 305 Rear
Notorious is offline   Reply With Quote
Old 11-29-2016, 12:27 PM   #2
Blk16SS
Blk16SS's Avatar
Drives: 2016 Chevy Camaro
How much
Blk16SS is offline   Reply With Quote
Old 11-29-2016, 01:53 PM   #3
Hard Parker
Hard Parker's Avatar
Drives: ZL1
A lot lol
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 11-30-2016, 03:42 AM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
What, that they offer, or the most powerful turbo kit for a 6th gen period?
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 11-30-2016, 06:31 AM   #5
Notorious
No Hope
Notorious's Avatar
Originally Posted by Blk16SS View Post
How much
He did not say what the pricing will be. I'm sure that will be released when the kit comes out.
You can probably bet on a full kit w/ tuner etc and a "Tuner" kit that comes with no handheld or tune etc.
Old 11-30-2016, 06:38 AM   #6
Notorious
No Hope
Notorious's Avatar
the most powerful power adder for a 6th Gen.
For ex, They made 726 RWHP on 9.8 psi of boost on a stock 5th gen SS with their TT Kit.
He didn't really give details on any specs or pricing as i am sure he is not ready to release that info yet. He only confirmed that a kit is coming and could see it's release in the spring.
Old 11-30-2016, 09:59 AM   #7
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Hmm, AGP turbo has made 1000 whp on the 5th gens with a stock bottom. Pardon my skepticism but I think someone really doesn't know what challenges they are getting into. The LT1 motor has a lot of complexities that no one ran into on the Gen 5 Camaro. That is why very, very few of these cars are making over 700 whp. Mine does and the only change in the motor is the LT4 mechanical fuel pump and injectors.
Hellion makes turbo systems that are pretty to look at but they typically don't make as much power as some of the other turbo systems on the market. This is because they place the turbos high in the engine bay which from basic physics is not the most efficient place to put them. I don't expect them to change their modus operandi for this kit. I suspect they are looking at the relatively low horsepower numbers the gen 6 forced induction cars are posting compared to gen 5 but these motors are not even close to equal. Read some of the other discussions on forced induction about LT1 fuel and compression ratio and you will get a better understanding of the limitations of the 6th gen motors. Eventually Hellion will figure this out. They make good kits but I'm fairly certain they are not going to set any power records in the 6th gen.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 11-30-2016, 10:12 AM   #8
1KillerSS
1KillerSS's Avatar
Took the words right out of my mouth....
Build thread
Old 11-30-2016, 10:35 AM   #9
parish8
Drives: 17 SS a8
I don't see the lt1 motor as anything all that different other than the di stuff. And if you want big power you are going to have to work around it.
Most power could be claimed many different ways.
Most power on a given boost level or on a given octane fuel I think will go to agp. Other than needing a scanvenge pump it seems like a much better way to do things for exhaust flow and controlling the heat.
Most power potential will go to whichever kit has the higher flowing turbos. If they put twin 62's(1400hp rated) on there it will be able to make more power before running out of turbo than the current agp kit(1100hp rated). I think the agp turbos will be well off the compressor map before they get to 550hp but the 62's might actually make it to 700hp and still be efficient.
Old 11-30-2016, 01:26 PM   #10
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
Thanks for the laugh, I just spit tea everywhere...
Perdieu is offline   Reply With Quote
Old 08-01-2017, 01:30 AM   #11
gippy87
Drives: 2016 2ss
and spring 2017 has come and gone. Crickets
gippy87 is offline   Reply With Quote
Old 08-01-2017, 10:07 AM   #12
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
oh snap
SSTony is offline   Reply With Quote
Old 09-04-2017, 09:31 PM   #13
Speedy1975
FASTER!
7psi 559hp 564tq
9psi 615hp 620tq
Atleast thats what they said on tv
Looks good on the car.
Interesting option.
$8995 msrp
