Old 11-28-2016, 10:27 PM   #1
ender2664
Drives: 2016 2SS
Procharger dyno graph
Anyone have a dyno graph of procharger vs stock on the same graph?
ender2664 is offline   Reply With Quote
Old 11-28-2016, 10:41 PM   #2
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
Not on the same chart but from the same place. Bottom of the article.
http://www.superchevy.com/how-to/eng...016-ss-camaro/
Sent from my SM-G920V using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 11-28-2016, 11:03 PM   #3
ender2664
Drives: 2016 2SS
I am trying to plot a graph that shows hp on the vertical and MPH on horizontal from 0mph to 100...to me it will show drivability. Don't know how much others would take from it, but I think it will let me get a good pic of things.
Old 11-28-2016, 11:09 PM   #4
sub_ETCS_ret
I don't think they do dyno graphs with MPH; just RPM and HP at least from what I've seen.
Old 11-28-2016, 11:19 PM   #5
ender2664
Drives: 2016 2SS
I agree. I'm going to print it, extract the info and switch rpm for MPH.
Not too hard a task but I'm going to play with gears to basically see what gear I'd be able to downshift to in order to hold the street.
Example-
50mph down shift to second would be about a 50hp difference between stock and procharger.
Old 11-28-2016, 11:20 PM   #6
sub_ETCS_ret
Got it. Good luck.
Old 11-28-2016, 11:21 PM   #7
ender2664
Drives: 2016 2SS
Got it. Good luck.
Thank you
I'm just really worried about traction and if it is going to prohibit the fun I can have on side streets.
Old 11-29-2016, 04:50 PM   #8
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Originally Posted by ender2664 View Post
Thank you
Unless you always disable traction control it really isn't much of an issues, you hit it, it gets sideways, the traction control comes on and it comes back in line, power comes on again.... if you like you can shift when the traction control comes on and the car has plenty of power to pull one gear high.... works for me. I get traction control everytime I hit it below about 50 mph. I have an auto so if I mash it, it always puts it in a gear that will blow the tires off but the paddles still work to upshift when the traction control is trying to reel it in. You can do the same with the clutch, that is how I drive my manual ZL1, when it starts getting sideways I just shift it in conjunction with the traction control.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 11-30-2016, 02:03 PM   #9
Slowhawk
Drives: 1999 Trans Am
Thank you
Well, you don't floor it all the time, control traction with the throttle.
Slowhawk is offline   Reply With Quote
Old 11-30-2016, 02:25 PM   #10
ender2664
Drives: 2016 2SS
Below 50 in 2nd?
Old 11-30-2016, 03:26 PM   #11
jessrayo
Speed Freak
jessrayo's Avatar
Below 50 in 2nd?
I don't understand the question. I'm usually in drive (I have automatic transmission) so the car is in who knows what gear whenever I decide to hit it. I seldom hit the paddles to prime it but it could be driven that way. Here is a copy of the transmission gear ratios so it is probable that it is going into 2nd gear if below 60mph.
Old 11-30-2016, 03:39 PM   #12
ender2664
Drives: 2016 2SS
Didn't see that u drive an auto. The question was assuming u had a manual. I was asking if you downshift to second doing 50 if you lose traction...Obviously different for manual than auto.
