Old 11-28-2016, 10:27 PM   #1
glovo
Drives: Camaro 2016 1LT RS
What tire learning progress means?
This messages came up on my Camaro 2016. I put air 2 days ago
glovo is offline   Reply With Quote
Old 11-28-2016, 10:34 PM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Did it beep at you, too?
Chances are, it's waiting for you to reset the tire pressures, one corner at a time, using a special dealership tool....
Go see a dealer, and they can complete the process...it takes 2 minutes, I can't imagine they'd charge you if you were nice.
Old 11-29-2016, 03:24 AM   #3
f0x
Drives: Silver 2016 Camaro R/S
Special tool...? Did they change it from all the other Camaros..? Used to just have to go to each corner starting from the passenger front letting air out until the horn honks on each tire...
f0x is offline   Reply With Quote
Old 11-29-2016, 03:42 AM   #4
fighting irish
The Doctor is in
fighting irish's Avatar
Drives: 2016 Camaro 2SS Nightfall MRC NPP
Yes, they changed it. You need this tool to relearn. The tool is quite easy to use as well. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
fighting irish is offline   Reply With Quote
Old 11-29-2016, 11:42 AM   #5
Mr. Wyndham
The let-air-out technique worked for everything up until 2012, I believe.
Since I swap wheels/tires twice a year, I bought the tool. It's even easier than the let-the-air-out technique. And you don't have to refill the tires!
Old 11-29-2016, 11:52 AM   #6
slick3
Drives: Garnet Red - 20 ZLE
On my 14 mustang I used to let all the air out on one corner at a time and then fill them back up and it would go away. Not sure if it works on the camaro
slick3 is offline   Reply With Quote
Old 11-29-2016, 11:56 AM   #7
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
It's thinking you're retraining the tire locations. Any respectful auto shop should be able to assist you. I'd do that before spending the $75 on the relearn tool.
edgehead2000 is offline   Reply With Quote
Old 11-29-2016, 12:13 PM   #8
Mr. Wyndham
Not anymore.
I agree.
Old 11-29-2016, 02:01 PM   #9
f0x
MAN, There always making changes to try and stop us from working on our own cars ourselves. Thanks for the info.. Im gonna get one of those tools...
Old 11-29-2016, 07:35 PM   #10
glovo
I think with the new 2016 it's different the message hasn't come up again and just took some air out and its showing the right psi
Old 11-29-2016, 08:23 PM   #11
Mr. Wyndham
It's possible that the system just reset itself, given no input...
Bottom line - you're fixed!
