11-28-2016, 12:01 PM | #1 |
Drives: 2017 ZL1 6M Hyper Blue Join Date: Sep 2016
'17 ZL1 ride height
Does anyone else out there feel like their front end is sitting just a little too high? The rear looks perfect, but my front end seems to sit up about 1 -1.5" higher than the rear & it's driving me NUTS! Has anyone heard anything about the fact that it could settle down a bit w/ more drive time, or am I just going to have to lower it myself?
11-28-2016, 12:07 PM | #2 |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
Did you check the springs? Might still have the shipping pucks.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
11-28-2016, 12:41 PM | #3 |
Drives: '69 RS Pro Street Join Date: Feb 2016
Too many people have reported the same thing. I find it hard to believe that so many dealers would have neglected to remove them prior to delivery. Many of the cars look nose up depending on the photograph. My suggestion is find a flat area and if you can shoot a laser line through the middle of the wheels on both sides. Measure the distance vertically from that centerline to the fender lip. That will give you a better indication. Suggesting that it will settle down is unlikely from my experience. Springs aren't going to relax 1.5 inches unless I'm crazy.
11-28-2016, 01:14 PM | #4 | |
11-28-2016, 01:17 PM | #5 |
Drives: 1970-1/2 Z-28, 2017 ZL1 Join Date: Sep 2012
mine sits great.
11-28-2016, 01:27 PM | #6 | |
I used to be Dragoneye...
Keep in mind, also, that while the tire profile is the same as the rear, the width is not....and that means the overall...the tire diameter is 1.2 cm shorter than the rear. Or about a half an inch. IMO, that's most of what we're seeing. |
11-28-2016, 01:35 PM | #7 |
Switch to SAE 90 weight oil. The heavier oil oughta bring that puppy down.
11-28-2016, 01:47 PM | #8 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
Maybe it is to balance the no lift shift?
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
11-28-2016, 01:48 PM | #9 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
It's odd, because all of the preproduction cars sat perfectly level and looked awesome. I can't remember seeing a customer car that didn't look high in the front.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
11-28-2016, 01:55 PM | #10 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
Here's a side by side comparison I made of the front fender gap of my ZL1 and that of a pre-prodcution ZL1. Sure looks like the gap is larger on my car.
11-28-2016, 01:59 PM | #11 |
Being high in the front should help put more weight on the rear for those hard launches, so maybe they put in the drag springs.
11-28-2016, 02:45 PM | #12 |
11-28-2016, 03:09 PM | #13 |
Drives: 2015 Sierra Join Date: Apr 2016
Could there possibly be a minimum clearance standard, and they had to raise the car the meet that. With the bigger grill or chin spoiler addition? I'm thinking like an internal standard not a DOT standard.
11-28-2016, 03:16 PM | #14 |
Drives: 2004 GTO & 2005 GTO Join Date: Mar 2014
Pre-production models are notorious for being slightly lower to the ground for visual appeal. My guess is federal requirements mandated they raise the front a bit for the production models.
Hell, take a look at the pre-production Z06's vs what production ones look like. The difference is jaw dropping. Luckily for Corvette owners, a simple bolt swap is all it takes to get them back down into the weeds. |
