Old 11-28-2016, 10:28 AM   #1
DFW1LE
DFW1LE's Avatar
Hood Wrap?
Not sure if anyone has had their car long enough to answer this, but what do you do for cleaning/detailing the hood wrap, spoiler, mirrors (e.g., do you apply any of these sealer products like you might on a painted surface)?
Old 11-28-2016, 10:31 AM   #2
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
There was a post a few weeks ago about this, a quick search should bring it up. Or just look farther down in the 1LE section.
seanblurr is offline   Reply With Quote
Old 11-28-2016, 10:44 AM   #3
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/86 IROC-Z
Spoiler and mirrors are painted. The hood is the only thing that is vinyl wrapped and would require special care. I believe Adam's makes a product that works well for keeping the wrap looking good. FWIW, I've seen some 1LEs that were daily driven for 3 years with no special care given to the hood. You can definitely tell if it has been cared for or not.
Old 11-28-2016, 11:01 AM   #4
KH6GEN1LE
Drives: 2017 Camaro 1le
Chemical Guy's also has a bunch of matte vinyl products. There's a seal and paint protectant. I recommend using that every couple of washes.
Chemical Guys offer a specific soap for matte vinyl cars, but I don't have an issue with using the Adam's soap for the whole car.
http://www.chemicalguys.com/SearchRe...h=matte&Submit=
KH6GEN1LE is offline   Reply With Quote
Old 11-28-2016, 11:03 AM   #5
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
My question for the guys that already have their cars is can we confirm that it is a 3M wrap??? I know the 5th gen was. I'm assuming it's 3M 1080 Matte Black but I want to confirm this so I can match it properly.
IG: @NC_M1SS1LE
Old 11-28-2016, 11:22 AM   #6
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
I've used this in the past with good results: http://www.chemicalguys.com/Meticulo...spi_995_16.htm
Old 11-28-2016, 11:30 AM   #7
tx6g1le
tx6g1le's Avatar
Drives: 2017 Camaro 1LE
I can confirm it's the 3M matte black. I posted a couple weeks ago about my vinyl installer told me to replace it with a satin black 3M as it tends to show everything.
tx6g1le is offline   Reply With Quote
Old 11-28-2016, 11:43 AM   #8
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Awesome thanks!
IG: @NC_M1SS1LE
Old 11-28-2016, 12:04 PM   #9
DFW1LE
DFW1LE's Avatar
Thanks, guys, found the other thread:http://www.camaro6.com/forums/showthread.php?t=470697
I will give the Chemical Guys stuff a try, once I get my car.
Old 11-28-2016, 12:06 PM   #10
Rafal
Drives: Sold - Krypton Green 1LE
What's under if you would want to remove it?
Rafal is offline   Reply With Quote
Old 11-28-2016, 12:22 PM   #11
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
It's painted same as the rest of the car.
IG: @NC_M1SS1LE
Old 11-28-2016, 12:47 PM   #12
Rafal
That's tempting. Is it hard to peel it off?
I assume if you want to do it you should do it quick before the rest of a car fades.
Old 11-28-2016, 12:49 PM   #13
Egon
Egon's Avatar
Drives: 2014 2SS/RS 1LE
As I mentioned in the other thread here, with my 5th Gen hood wrap now that I live in an area where we have soft water all you need to do is wash with soap and water and dry it after. Chemical Guys Meticulous Matte Detailer is great to use after washing to make it spotless. If you live in an area with hard water, like when I lived in Southern California, you need to be fast and dry the hood immediately after washing with soap and water to prevent water spots. There will almost always be some even with that method but it will be minimal. I would not recommend any sealants or waxes after cleaning if you want to maintain the matte finish, as they will cause it to shine. The wrap is pretty rugged and doesn't really need any protectants anyways.
Egon is offline   Reply With Quote
Old 11-28-2016, 01:20 PM   #14
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
It's 2016...between modern paint, and modern detailing equipment, the paint will not fade. Especially if the car is garaged. I removed the side stripes from a Mustang I owned that was five years old, and the paint tone was no different. No worries about that...
