11-26-2016, 06:25 AM | #1 |
Drives: 2017 ZL1 Join Date: Nov 2016
Wheels/Bolt Pattern
So I am coming from the Mustang world and this is my first Camaro. Mustangs had the same bolt pattern and one wheel would fit many different years.
Does the same hold true for Camaros? What about Corvettes? For example would a 2011 ZR1 wheel fit my '17 ZL1, etc. Will be looking into a drag setup, and wondering what forums/groups I could look in other than just 6th gen Camaro forums. Thanks for the help everyone!
2017 Camaro ZL1
Instagram: @ZL1_Tommy Youtube: ZL1 Tommy |
11-26-2016, 07:19 AM | #2 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
The 5th and 6th gen Camaros share the same bolt pattern ( 5 x 120). Everything on the C6 ZR1 I found showed a bolt pattern of 5 x 120.65.
Camaro5.com and LS1Tech.com would be two other source of drag racing setup info.
11-26-2016, 07:22 AM | #3 |
Bolt patterns are the same on Camaros and Corvettes. Offset is different so vette wheels don't clear the brembo brakes on the Camaro. But Camaro to Camaro they can be swapped. I have a set of Welds from my 5th Gen ZL1 that I plan to use on the 6th Gen Z.
One you start moving away from stock sizes the model to model clearances can be a bit tighter such as 17" wheels clearing brakes, LCA and e-brake lines. Some even change their brakes to V6 ones so they can get smaller diameter wheels on. The high end wheel makers nail the spec very well. You're welcome to test fit my welds if you want to check before buying something. Size and pics are posted here. http://www.camaro5.com/forums/showpo...postcount=1096 ...and here is a thread that might interest you. http://www.camaro5.com/forums/showthread.php?t=392950 Time for some track testing too... http://www.camaro5.com/forums/showth...04361&page=149 |
11-26-2016, 10:49 AM | #4 |
noob
Drives: 2017 ZL1 M6 Join Date: Sep 2016
This in and of itself is worthy of celebration and congratulations! Welcome to the dark side
11-26-2016, 12:41 PM | #5 | |
2017 Camaro ZL1
