Old 11-25-2016, 07:49 PM   #1
16CamaroSS
Drives: 2016 Summit White Camaro SS (2SS)
Road Trip Fuel Economy
For the curious. Just did a road trip that was roughly 500 miles in each direction going from about 1,000 feet elevation to 5,500 feet.
On the uphill trip, mileage was 26.5 mpg. On the downhill return it was 29.5.
Was on cruise control 95% of the time at 5 over the limit on interstates and highways (limits between 55-75).
16CamaroSS is offline   Reply With Quote
Old 11-25-2016, 09:36 PM   #2
Genesis7
Drives: 2SS
thats good for a V8.
Genesis7 is offline   Reply With Quote
Old 11-25-2016, 09:40 PM   #3
quikag
Drives: 2SS '16 Camaro
I cracked 30mpg at a steady 65mph cruise on the 50 mile average gauge. Very impressive for a 455hp 6.2L V8!
'16 2SS White/Adrenaline Red Coupe Mag ride, 8-speed, Sunroof, Dual-Mode Exhaust, Black wheels
Also:
2010 ZR1
2018 GT3
2013 LX570
quikag is offline   Reply With Quote
Old 11-25-2016, 11:28 PM   #4
c4racer
Drives: 2016 SS Convertible
Better than I've seen. But not really broken in yet either.
c4racer is offline   Reply With Quote
Old 11-26-2016, 09:47 AM   #5
Frank237
Frank237's Avatar
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS
Amazing! My first two tanks (partials) showed 20.9 and 21.1 mpg, I was amazed it would be that high. Considering the new engine and how tight it is.
Love that fuel management software.
Frank237 is offline   Reply With Quote
Old 11-26-2016, 02:53 PM   #6
thickstunalex
Drives: Coming: 2017 Camaro SS Vert
I can get quite impressive fuel economy when I try. This is also the first car I've owned that counted fuel economy when the car is stopped, making it much more accurate.
09/20/16 - 1100 10/25/16 - 4300
09/30/16 - 3000 11/09/16 - 4200
10/05/16 - 3100 11/14/16 - 4500
10/07/16 - 3400 11/16/16 - Driving!
thickstunalex is offline   Reply With Quote
Old 11-26-2016, 03:31 PM   #7
fighting irish
The Doctor is in
fighting irish's Avatar
Drives: 2016 Camaro 2SS Nightfall MRC NPP
2SS M6 here- 25-27mpg seems to be about the norm with cruise set between 70-75mph.
fighting irish is offline   Reply With Quote
Old 11-27-2016, 05:31 PM   #8
1fujifilm
Drives: 2019 Mustang GT Convertible
Just an FYI on my 16 1SS Convertible. My "displayed gas mileage" is off my about 8%. It shows 22mpg on the DIC and when I figure it manually it is only18 mpg.
Bear
1fujifilm is offline   Reply With Quote
Old 11-27-2016, 05:52 PM   #9
Frank237
Frank237's Avatar
Bear
That IS figured out the old fashion way...using math. I was also not going much over 3500 rpm and babying it during break in.
With 500 miles on now, I got on it a bit more yesterday and mpg shrank
significantly.
Old 11-27-2016, 06:22 PM   #10
fighting irish
The Doctor is in
Bear
On the M6 SS coupe, I have found it to be off/optimistic by 2.5% each time I hand calculate (have done it 4x).
Old 11-27-2016, 10:03 PM   #11
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
I noticed every time I fill it I can put about 6/10ths of a gallon MORE than the "Fuel Used" value in the DIC.... so I figure all the MPG calculations are probably off by about 3 to 4%
I noticed this on the first fill but figured I topped it off more than the last refill and it would average out... but it is consistently off.
crazydmc is offline   Reply With Quote
Old 11-27-2016, 10:10 PM   #12
Jackass
Doing what I like to do
Jackass's Avatar
Drives: 1963 Landrover
significantly.
That's normal , picture this , if you are running a mile in 3 minutes you will be consuming a certain amount a oxigen , but if you try and do that same mile , under the same exact exterior conditions , but you push yourself do do it at let's say 2.35 , you will burn more fuel ( oxigen ) in this case , that's a fact
Jackass is offline   Reply With Quote
Old 11-27-2016, 10:40 PM   #13
ender2664
Drives: 2016 2SS
I drive from 0 elevation to 0 elevation 120 miles each way weekly 72mph average and average 29-31mpg.
Best was 31.6mpg with a 71mph average.
Those are all numbers when she was 100% stock.
Car gets much worse mpg over 75.
ender2664 is offline   Reply With Quote
Old 11-27-2016, 10:52 PM   #14
camex
Drives: Sold
Wow, great MPG for the V8!
camex is offline   Reply With Quote
mpg fuel economy
