Old 11-25-2016, 03:47 PM   #1
gosutag
Left Lane Enforcer
Drives: '18 ZL1 1LE.
Straight pipe camaro NPP system and remove muffler?
What are the pros and cons of it?
Where in NY can I get it done?
How much would it cost?
Do I need a tune after?
How much would that cost?
What's your opinion?
Current Cars:
2018 Camaro ZL1 1LE
2012 Ford Focus SE
1994 Evo II
Previous Cars:
2017 Camaro SS
2014 Chevy Malibu LTZ
gosutag is offline   Reply With Quote
Old 11-25-2016, 04:46 PM   #2
slick3
Drives: Garnet Red - 20 ZLE
Pros: Subjective... Louder Cons: Louder
No idea, you need a muffler delete with NPP? Sounds counter intuitive?
If after cats, no tune is needed
Too Loud all the time, not for me, you paid 900 bucks for NPP why remove it all together. Get some Borla ATAK w/ npp valves if you are looking for sound.
-Or better yet, Electronic cut outs before the rear axle if you want loud for much cheaper.
slick3 is offline   Reply With Quote
Old 11-25-2016, 08:04 PM   #3
gosutag
Left Lane Enforcer
My only reason for getting rid of the suitcase is literally to only get rid of the suitcase. I was just wondering what comes with doing so
Current Cars:
2018 Camaro ZL1 1LE
2012 Ford Focus SE
1994 Evo II
Previous Cars:
2017 Camaro SS
Old 11-25-2016, 08:44 PM   #4
mariojmoe
Drives: C7 Z06 manual, 18 Zl1 manual, etc
I looked into this as well op and have npp. With the black friday sales you can do like I did and pick up a cheap catback exhaust for dang good price. I am ditching the npp altogether bc I like loud all the time. It was a waste to me tbh. Went with mbrp race 3" stainless.
mariojmoe is offline   Reply With Quote
Old 11-25-2016, 09:04 PM   #5
1slowssm6
Drives: 2016 1ss m6 Camaro
npp was worth it to me for the gloss rear insert vs the ugly crap you get with the single tip non npp
2016 camaro 1ss,m6-npp,tsp longtubes,no cats,e85,tuned by rpm motorsports(451hp/467tq),
17"race stars drag pack,bmr upper and lower trailing arms,bmr upper control arms,bmr front cradle brace,gforce outlaw axles/driveshaft,lnf 2step.
Best 1/4 mile of 11.2@122mph
1slowssm6 is offline   Reply With Quote
Old 11-25-2016, 10:21 PM   #6
laynlo15
Drives: 2022 Lt1 A10
Why? Not loud enough? Short dick loud car? just kidding. Maybe I'm just old. just remove the fuse , loud all the time
Old 11-25-2016, 11:45 PM   #7
Blk16SS
Blk16SS's Avatar
Drives: 2016 Chevy Camaro
I'm trying to incorporate and justify buying these. By the time I get everything to make the conversion, I will be at 650-700 bucks. Hell I would be too close to just getting an axle back..
Blk16SS is offline   Reply With Quote
Old 11-25-2016, 11:46 PM   #8
gosutag
Left Lane Enforcer
I am solely interested in removing the muffler for cosmetic reasons and wondering what comes with that.
Current Cars:
2018 Camaro ZL1 1LE
2012 Ford Focus SE
1994 Evo II
Previous Cars:
2017 Camaro SS
Old 11-25-2016, 11:56 PM   #9
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
There are a lot of aftermarket axle back systems that require cutting the exhaust right before the suitcase and keep the NPP function. If you want just straight pipes then you could have an exhaust shop build something. But you will lose the NPP unless you chop that section off and get fancy with some mufflers. Another member on here did it with a pair of flowmaster mufflers.
Old 11-26-2016, 12:54 AM   #10
Whitemaro6
Whitemaro6's Avatar
Drives: 16 Summit white, Ceramic white 2SS
that system looks interesting
Whitemaro6 is offline   Reply With Quote
Old 11-26-2016, 02:13 AM   #11
Blk16SS
Blk16SS's Avatar
The Warlock muffler sounds really good. If you welded the factory valve to the straight through circuit, you would still utilize the NPP function. It would be a "mellow " mode as opposed to stealth mode. (6) 45 degree angle stainless steel pipe pieces are needed with these mufflers and they aren't cheap . The only problem I see is the muffler is 3" in/out. Those valves are no larger than 2 3/4".....
Old 11-26-2016, 06:39 AM   #12
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
EXACTLY!!!
I did that and a secondary cat delete and its LOUD.
IF anything remove the suitcases for weight purposes and replace it with another dual mode npp system with smaller damn muffs. OR keep the dumpsters on there and get cutouts.
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
Old 11-26-2016, 11:36 AM   #13
ender2664
Drives: 2016 2SS
I deleted the stock npp and it sounds amazing. I'm told often that it sounds the way the car should have from the factory.
ender2664 is offline   Reply With Quote
Old 11-26-2016, 11:45 AM   #14
KILLA BEE
Black lightning
KILLA BEE's Avatar
Did you get an axel back like your post describes or did you just swap out the muffler for 3in straight pipes
