Old 11-22-2016, 12:21 AM   #1
aa406079
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6
Tire temperature menu?
I know the ZL one gets one but I wasn't sure if the 1LE got this as a hand me down… In any case I'm sure in a year or so there will be hacks to enable it my link system
aa406079 is offline   Reply With Quote
Old 11-22-2016, 03:56 AM   #2
B88
B88's Avatar
Drives: 17 Black 1LE, Big Brown Truck
Yes the 1LE has it.
Black 2017 Camaro 1SS 1LE
9/29 - 1100
10/4 - 2000
10/8 - 3000
10/18 - 3400 TPW 10/24
10/27 - 3800 built
11/10 - 4B00
11/11 - 4300
11/18 - 6000 Delivered!!
B88 is offline   Reply With Quote
Old 11-22-2016, 07:07 AM   #3
TJay74
Yes it has it, it will be under the performance menu. It is listed with the 2 different G force screens.
Old 11-22-2016, 08:22 AM   #4
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Wow, I had no idea about this...
Old 11-22-2016, 08:31 AM   #5
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Neither did I.
I remember reading about it in a Z06 article. Apparently, a newer TPMS sensor had an internal temperature sensor for the circuit board, that ID'd three zones of temperature. The reading wasn't intended to provide data to the driver....but Corvette engineers were able to utilize that data to display those three temperature ranges on the DIC.
Pretty cool to see it in Camaro!
Old 11-22-2016, 08:35 AM   #6
ChevyRules
Drives: 2021 Tesla Model 3 LR
Even the regular SS has this feature. Found it myself when I went in for my second test drive of the Camaro last week.
ChevyRules is offline   Reply With Quote
Old 11-22-2016, 09:02 AM   #7
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
That's awesome!! Now we can monitor our tire pressures at different temperatures in real time and dial our grip in. outstanding.
Thor142 is offline   Reply With Quote
Old 11-22-2016, 09:40 AM   #8
Mr. Wyndham
Just keep in mind, if it's the same as the C7s system...it's only going to read ranges...
Integrated Tire Temperature/Chassis Controls
Chevy uses the tire temperature data available through the C7's tire pressure sensors to more carefully control its ABS and electronic differential. Because the pressure sensors don't measure tire temperature directly (they actually measure the temperature of the TPMS sensor's microprocessor), it's not a perfect science, but it is one that data modeling can largely overcome. And it's one more piece of information that can be utilized to enhance the driving experience.
Tire temps are split into three categories: cold (below 45 degrees), warm (45-115 degrees) and hot (above 115 degrees). In "cold" mode ABS intervenes sooner and more progressively, while the differential is more aggressive to limit inside wheelspin. As temps increase, ABS control intervenes later and becomes more lenient, while differential locking ramps up more slowly.
Old 11-22-2016, 09:58 AM   #9
Thor142
Thor142's Avatar
I thought it was a little too good to be true the way I was understanding it.
Old 11-22-2016, 10:08 AM   #10
Mr. Wyndham
Yeah. It's a step in the right direction, though!
Maybe the next-gen TPMS sensors will display more accurate ranges?
Old 11-22-2016, 11:24 AM   #11
Thor142
Thor142's Avatar
I do ok with tire pressures using my IR temp gun after I get off the track and high quality pressure gauge. I don't think the tire lose too much heat from the checkered flag to pits. It would certainly be cool to have real time temps at a glance on the track though!!
Old 03-23-2017, 09:01 PM   #12
booyaa56
booyaa56's Avatar
Drives: 2017 Camaro 1LE
Is there a part number for this sensor?
booyaa56 is offline   Reply With Quote
Old 03-23-2017, 10:47 PM   #13
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
All 2017 SS have this. Pretty jealous.
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 03-24-2017, 10:45 AM   #14
171LE
Drives: 2017 Camaro 1SS 1LE Nightfall Grey
Mine displays:
Cold
Cool
Normal
I have not seen hot yet...
171LE is offline   Reply With Quote
