Old 11-18-2016, 05:57 PM   #1
Giri
Soon to be Millionaire
Drives: Blue 2016 Camaro
Hardwiring Wifi Router in Trunk
Hey Guys!
I'm trying to now hardwire a LTE hotspot in my trunk (free to add an extra line and therefore better than onstar's data) and am trying to find a switched power fuse to tap in the rear fuse box.
Is there one?
Also, where should I connect the negative wire of the hardwire kit to?
Giri is offline   Reply With Quote
Old 06-07-2019, 03:18 PM   #2
bereic
bereic's Avatar
Drives: Camaro SS 2018 Convertible
did you have success with that ?
bereic is offline   Reply With Quote
Old 06-07-2019, 05:43 PM   #3
Giri
Actually, no :( I'm tapped into one of the fuses that is always hot but it's a massive pain since I have to unplug every time or my battery will die
I run a Drone Service Company in Gainesville, FL - Please visit my site and take a look
Old 06-08-2019, 09:50 PM   #4
Oramac2016
Oramac2016's Avatar
Drives: 2016 Camaro RS
This isnt the trunk but you could tap the cigarette lighter its switched. Then you could place the hotspot sort of behind the center vents. There is an opening right behind your kneepad.
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
Oramac2016 is offline   Reply With Quote
Old 06-09-2019, 10:56 AM   #5
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
Plug in a relay that will cut the circuit whenever the car turns off. Wire it to something that is active only when the car is running.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
